2007 4runner spark plugs
NGK and Denso are the OEM plug manufacturers for Toyota. Either one will do nicely. You do NOT have to buy them from Toyota dealer and pay 3-4 times for the EXACT SAME PLUG you can get at your local parts store or on-line.
I would run Denso or NGKs, the non-Japanese stuff seems not to play well in Japanese cars (I'm guessing they're a bit racist that way? lol)
The Single VVTi 1GR-FE (4.0L V6) that you have uses Copper Electrode plugs that have a service interval of 30k. You can always upgrade to Iridium if you want them to last longer, but performance does not really change.
Auto-Lite, AC/Delco, Champion all make plugs for the 4runner. But I wouldn't use them. If I owned a GM - I'd use AC/Delco plugs. NGK and Denso make good quality plugs. Some 30 years ago I had a problem with Nippondenso (now called Dens0) plugs. I put a set of plugs on my wife's Datsun 510. They worked fine, but had an awful lot of radio static. I guess the resistor on one or two of the 8 plugs had a problem. Replaced them with NGK and no more problem.
Back in the day, that's what My father used on his Datsun B210 wagon(Speaking about the Nippondenso that is).
Why did the original 2007 V6 SR5 2WD come from the factory with 3 Denso in one bank and 3 NGK in the other? Why would the owner’s manual list changing these plugs at 30,000 mi when they are known to last much longer?
At my 43,000 mi Certified purchase they had not been changed because they d/n need changing. I asked if the engine had a problem in the 7yr/75,000 mi Factory Warr and could be related to the plugs, what would happen. They replaced the plugs which I agreed were good (after they listed a few emission matters plugs possibly could be related to).
Was this corrected with plugs later in T4R? Looking in a 2010 Highlander’s 4 Cyl’s service manual I d/n see a listed plug change up to 90,000. I expected to see 90,000 mi or did I miss it or fine print (as inspect)?
Why did the original 2007 V6 SR5 2WD come from the factory with 3 Denso in one bank and 3 NGK in the other? Why would the owner’s manual list changing these plugs at 30,000 mi when they are known to last much longer? this corrected with plugs later in T4R? Looking in a 2010 Highlander’s 4 Cyl’s service manual I d/n see a listed plug change up to 90,000. I expected to see 90,000 mi or did I miss it or fine print (as inspect)?
Look at the 120k service interval. The plugs should be there.
The Highlander probably uses Iridium or Platinum plugs. These plugs last a lot longer then regular Nickle coated plugs. If the vehicle doesn't call for the Iridium or platinum plug and they're easier to change then just use the regular plugs.
I'm over 100k too. What's the original plugs, regular, Iridium, or platinum. Since they last this long, I don't think they're regular.
Look at BlackWorksInc entry above. The plugs are copper and supposed to be changed every 30K miles. I bought my ’08 4Runner with 88K miles that had the original plugs. It ran great but when I pulled them to put new plugs in the gap was huge. Probably close to twice the normal gap.
I’d recommend changing as soon as possible. I can’t imagine it’s good for the catalytic converters.
I just changed my spark plugs with the OEM Denso's on my '06 2wd v6 - they work great. I noticed that on plug 6 there was a little bit of oil on it. do any of you know what could cause that? everything else is working fine. I really don't want to take it into the dealership for their opinion.
I could be wrong but that may mean it doesn't fire. Should at least ask an mechanic or someone here may be able to confirm what I said.
On most vehicles with plugs that go into the head through the valve cover, there are seals down inside the valve cover that keep the oil in... One is probably going bad.
Ok, out of the blue, I wanted to change mine. Driver's side, how do the clips come apart?? I sure do not want to break it. If this is like the connector for the turn signals, it is not coming apart. ???? Passenger side was fine.
___________
2007 SE V6, Titanium
AndiGarage
