tjhaf2007
I recently picked up a 2007 V6 Limited 4WD w/81k on it. It has "service records" on carfax, but i dont know what all has been done "tune-up" wise. I plan on doing a full on tune up on it, both engine and fluids. Ive come up with a list of things to do for a tune up, but i want to see if im missing anything or if you guys would recommend something i didnt mention. Ive only had it for about a month, it came from PA and therefore has some minor corrosion on the chassis, due to the harsher weather and road conditions over there.
Engine Tune Up:
Oil and Filter Change
Replace Spark Plugs - NGK Laser Iridium 4904
Replace Air Filter
Replace PCV
Clean TB
Suspension/Chassis:
Lube Drive Shafts and U-Joints - Mobil 1 Synthetic Grease
Fluid Replacement:
Replace Front and Rear Diff Fluids
Replace A/T and T-Case Fluid
Engine Tune Up:
Replace Air Filter
Replace PCV
Clean TB
Suspension/Chassis:
Fluid Replacement:
