2010 Satellite Radio "No Signal" Issue
Stewart
I've read every thread I could find on this topic but I cant seem to find the detail I need.
Equipment:
2010 SR5. Satellite Radio, No Nav. CD Changer. Party Mode - Im assuming that this was the standard head unit in 2010.
Background:
The Sat Radio (SiruisXm) has worked flawlessly since I bought the truck. Over the past 4 weeks, The Signal Loss / Fade In / Out has become more frequent, Now, it cant find a signal 90% of the time.
Ive tried the Satellite signal updates - Still no fix.
Assumptions:
I believe this to be an antenna issue based on all of the threads Ive found here. The head unit seems to be working normally - I can receive FM and AM stations without Issue. All buttons work etc.
Since I believe this to be Shark Fin antenna related, my question is: Where does the antenna coax attach to the head unit OR is there a separate Satellite module? Ive read a post about this module being under the passenger seat but I cant confirm.
Does anyone have a part numbers / links to the parts I may need to replace the antenna? (It doesnt need to be a new shark fin or even mount in the same location.
Insights are greatly appreciated.
Equipment:
Background:
Assumptions:
i replaced the shark fin with a corolla xm antenna. easy to install and signal was much better.
Genuine OEM Radio Antenna Assembly for Toyota 8696006030C0 | eBay
Check to make sure the bolt that grounds the antenna to the roof isn't loose. I had this issue after going through a car wash that had a very strong dryer.
2001ATL
