2013 tacoma spacer fit 08 4runner?
wasnt able to confirm if these spacers will fit a 4th gen 4runner.... anyone know if spacers from a 13 tacoma will fit/work on a 08 4runner 4wd?
im considering raising the front of my 4runner to level it out on a budget & found some 1" spacers but the guy says they were on a 2013 tacoma. just want to be sure they will fit before i buy them.
ive tried searching & reading through pages of stickies & still not 100% sure if spacers for a 2013 tacoma will fit.
forgive my ignorance here, but can anyone confirm this? i assume if shocks/springs from this year tacoma will fit 4th gen 4runners that the spacers will fit too, just want to be sure before buying them?
Surprised no one else replied.
They should work just fine. I have Tacoma front shocks on my 4Runner and everything bolts right in, I'd assume whatever spacers he has (brand wise) are probably marketed as fitting both because the bolt pattern of the top of the shock is the same between the two.
My suggestion is to take the spacers to an auto part store, assuming you have them in hand. And then have the guy at the counter find a pair of struts for a 4runner and see if the holes line up...should be fine though.
Rather than actually waste a parts guys time (unless you know one that is bored). Here's the easy way to confirm.
Daystar™ - Driven by Design
You'll see that this fits both the 03-09 4Runner and 05-17 Tacoma. That's the easy indicator I use when looking if something will fit.
thank you for the replies. sounds like they should fit.
i do not have them in hand, considering buying some from a guy that can only say they came off a 2013 tacoma. not sure of brand but look to be in great shape for a good price.
Front end suspension setup of 4th gen 4runner and 2nd gen tacoma and FJ cruiser are very close to identical....5th gens too lol.
I'd say its a good buy, especially if you're lifting on a budget, that's where I find alot of the parts I use.
