2014 - 5th gen Rear view camera backup not working
Thank you
Long time lurker, first time poster.
I've had this issue for quite some time but been too lazy to investigate. Finally got around to it. Long story short, I believe there is a plug that has too much tension which forced a connector to be loose in the plug. To fix, I cut tape (relieve tension) and added a zip tie (secured the plug). Been testing this about a week with my tailgate panel off. Steps & pictures below.
1. Remove both rear lights on the panel. I used a plastic pry tool to pop them out. Unclip & remove. You do not need to remove the 10mm bolt behind the lights.
2. Remove the cover from the grab handle. There is a 10mm bolt behind it. Remove the bolt.
3. Use a plastic pry tool to carefully go around the panel and pop off the panel. It should just be plastic clips along the side & bottom.
4. In the center of the door you will see a metal bracket, black box, and a few plugs. Disconnect the harness that is not directly connected the black box (see attached pictures). In my case, a few of those wires were bent and slightly loose. I pressed on them with my fingers just to straighten them out.
5. The plug above is also secured to another harness using tape. Cut that tape. This should allow the harness to not have as much pressure.
6. Plug it back in. To take it a step further, I zip-tied that plug together to ensure a solid connection.
7. Put it all back together.
I did this today on my 2015 Ltd. I was having the intermittent camera problem for a few years. Recently it has been off for a week so I came here looking for help. It's fixed for now (Jan. 5, 2026). We'll see if it lasts. Thanks!
Kudos on this fix GoHeels!
I've been suffering through intermittent backup camera woes for over a year in my 2014 Limited. Last week it just went black and stayed that way. I suspected that it was tailgate wiring related as the head unit knew the car was in reverse and the image was good (when it was working.) Used a cheap scanner to pull codes and found a C1622. Searched on T4R.org and ended up on your post. Great pics and narrative. Worked just fine. Used your ziptie mod for good measure. Can't say thank you enough.
I posted on January 5 when I performed this fix. I'm following up to say that it has 100% worked. It's April 23 and I have never experienced the black screen since. Thanks again.
seltzernator
