2015 trail loose change sound
Frat_4runner
2015 trail noises EDITED
alright I've searched until my fingers have bled over this, I've taken it to the dealer and he gave me a dead end explanation that made me feel like he didn't want to deal with it, I've checked countless times to find the problem but have come up with nothing. i have a 2015 trail edition a few weeks after i got it (possibly had it when i got the car) it started making a loose change metallic jingling sound over any small bumps, rough rode, pot hole, etc. i do have a lift kit but the sound was there before i had it installed. it hasn't gotten worse or better but it does stop completely when I've been out wheeling and gone through thick mud that gets all in my suspension, but me being OCD about the cleanliness of undercarriage i get all the mud out and it comes the sound comes right back. I'm inclined to believe what my sub par local toyota tech has said which is that it is my "free float braking system" can anybody. it makes a very similar sound when my crawl control is activated. i can only hear it when i have the windows down too. would somebody like to elaborate or give their 2 cents on what it could be?
1ST MYSTERY SOLVED IT WAS INFACT THE C PIN CONNECTING THE SPINDLE TO THE UCA.
2nd noise I've run across is any time i dip into the water like a creek or wash off my underneath side like brakes, CVs, LCAs, UCAs, Coilovers, etc. i get a noise coming from my front end (sounds like a wire brush on my brake caliper) when i drive. it dosent happen often and seems to go away as soon as it dries. Im thinking its the brake pads rubbing the caliper with dirt and such in it. anybody have anything to say about that while we are on the topic of noises
EDIT: added another noise question
Your radio volume is too low.
Seriously, it could be almost anything. Loose heat shield, loose skid plate, anything. Start by rolling down all windows and having a passenger move around the cab trying to locate the direction. Then try to get it on a lift so you can get under it and start jiggling things.
When I have a loose change sound it's because my wife tossed something in the 4WD shift boot.
There's a thread around here somewhere about the clip on the upper ball joint jingling... A few people seemed to have that problem on the thread
I'll see if I can find it
Kids ever ride in your car? I can't tell you the amount of loose stuff they leave behind and in areas you wouldn't believe to look.
It's the brake calipers. It's part of the vehicle star safety system... Vehicle stability control if I'm not mistaken.Kinda like abs but a little different it works separately on each wheel
this thread reminds me of my 3 year old. Had a 2007 tacoma and took my 3 year old at the time to the car wash. while i was washing my truck outside, he was inside the truck sticking quarters in my cd changer. and it ended up blowing a fuse in there. lol
It's the c-clip around the upper ball joints. Had the same issue. Dealer wound up replacing the entire upper control arms on both sides. Seems to be a quality control issue, my wife also has a '15 SR5P and hers didn't have the issue, mine did.
hahahah wow that sucks!
I had my spare tire out the other day to do my diff breather and noticed the chain that raises and lowers the spare was jingling when I went to run a quick errand - have you checked that chain on yours?
yeah i knew that wasn't it though be cause the sound was coming from the front end.
loose change noise solved! took some 1/4 inch wide zip ties and zipped them in-between the C-ring and UCA and no more noise. SUPER quick and easy way to eliminate the annoying sound it creates if you're having the problem.
Glad you got it figured out.
I have seen quite a few vehicles that have similar symptoms and a common culprit is heat shields. Due to how thin some of them are they are easy to get bent a bit and start hitting things like the catalytic convertor.
If they do, they make a tinny rattle that will drive a person nuts.
alexaturner
