2016 4Runner light bar install help
Travo60
Hello fellow 4Runner owners,
After spending quite some time searching for a write up, I have come up empty handed.
I'm looking for some assistance in a light bar install on my Gobi Steal roof rack. My issue is running the wires through the back end near the spoiler. My question is where exactly is the point of entry? Also, once you are able to get the wires in, how would you go about running them all the way to the front of the car for power/switch control. Any information is greatly appreciated.
There you go.... :pop2:
Finally got the rack and light installed. The light wiring was a lot easier than anticipated. From the battery into the cab, I used the hole were the main wiring harnesses went through. Plenty of room, just cut an additional slit in the rubber housing that seals the hole in the firewall. Going from the battery up to the light I ran it to the windshield, for the length of the windshield I removed the black housing that the wires were in. I tucked the wires in along side the windshield with the negative wire in top. Very clean look an barely noticeable. From the top of the windshield to the gobi mount, I tucked it under the black rubber that goes along the roof above doors. Once to the mount, just ran up along the bottom rack and plugged in. Works and looks great. I will post some more detail pics soon.
seltzernator
