2016 Easter Jeep Safari
It will all depend on what trails you do....
But going with a group of jeeps will typically get you in trouble very quickly...
Some used tires (like the ones posted above) will help you out quite a bit. Also, keep your trail weight down as much as possible. Don't carry anything you don't need.
PSI for airing down totally depends on the tires you are running... I have no idea with stock P rated tires.
Do you have a trail edition or sr5? An aftermarket gas tank skid is a really good idea.... IF you have an sr5 it is mandatory... Trail, you might squeeze by with the stock skid.
Thanks for the tips. It's a trail edition. I need to check on a good air down pressure.
Not just that, but they have stiffer sidewalls and a heavy construction to resist sidewalls punctures and the ability to air down more reliably without popping a bead
Bingo, when aired down damn near 50 percent of my sidewalls make contact with the ground.
Thundro
