2018 OEM Roof Rails Torque Spec
chon79
Member
Does anyone know what the torque spec is for the OEM roof rails? Removing to have them powdercoated and want to make sure I get everything back to spec to avoid leaking.
when you take the factory bolts off use a torque wrench in reverse and test them until the bolt breaks. you wont have the exact number but close enough for a roof rack.
set the wrench at 15, try it, then 20 try it, then 25, try it and so on until the bolt loosens.
Jhunt
