2019 King lift question
I am looking at switching out the suspension on my 2019 TRD PRO for King, I found the one I want at the below link. Can someone please explain to me if there is an advantage or disadvantage to using the light racing UCA?
King 3" Performance Lift Kit for a 2010-2020 Toyota 4Runner
looks like a $135.12 disadvantage to me.
But seriously the TC is a uni ball and the SPC is a ball joint. Ball joint will be less maintenance and most likely longer lasting. The TC has urethane bushings and the SPC has rubber. Urethane would generally be considered better. I believe the SPC allows for a bit more caster adjustment. The other differences are subjective.
Hello sir!
Anthony from Toyteclifts here. The gentlemen above me is correct with his state 100%. SPC is very popular due two the main fact that you can pull your tires forward about an inch away from your body mount to help with tire fitment. The link you provided is actually the kit from us here at Toytec. Let me know if you need help! We even had a forum discount that works on that kit. You can even give me a call at Toyteclifts 303-255-4959 ext 113
Also, Toytec has superior customer service, compared to BL. I am shopping for new coilovers for my 4r, reached out to BL for suggestions and it was obvious the person I was conversing with, had no clue what they were talking about. Via email, they don’t have a phone option.
I’ve called Toytec several times over the couple I’ve owned my 4R and have nothing but good to say about them.
seltzernator
