2020 7th Gen Wish List
st8rocks
On the recommendation of a wise man/reason to start another pointless thread... What do you want to see on the 7th gen Runner??
if they keep the BOF then maybe bring SAS up front to the states! that WON'T happen lol.. V8 and or Diesel.. more so diesel.. and i want it to make some decent numbers. that's about it.
Code:
Predecessor  1st Gen     2nd Gen     3rd Gen     4th Gen     5th Gen     6th Gen     7th Gen
Prod Model   Prod Model  Prod Model  Prod Model  Prod Model  Prod Model  Prod Model  Prod Model
1981 1981    1984 1984   1989        1995        2002        2009        2016        2023
1982 1982    1985 1985   1990 1990   1996 1996   2003 2003   2010 2010   2017 2017   2024 2024
1983 1983    1986 1986   1991 1991   1997 1997   2004 2004   2011 2011   2018 2018   2025 2025
             1987 1987   1992 1992   1998 1998   2005 2005   2012 2012   2019 2019   2026 2026
             1988 1988   1993 1993   1999 1999   2006 2006   2013 2013   2020 2020   2027 2027
             1989 1989   1994 1994   2000 2000   2007 2007   2014 2014   2021 2021   2028 2028
                         1995 1995   2001 2001   2008 2008   2015 2015   2022 2022   2029 2029
                                     2002 2002   2009 2009   2016 2016   2023 2023   2030 2030
6th Gen Wish List:
1. Aluminum engine blocks with thick enough piston sleeves that can be bored out, and otherwise rebuilt.
2. Better head-to-block fitment with improved head gasket seals, especially for those who want to add forced induction.
3. Wider rear solid axle to allow for a wider track and allow for a better articulation angle.
4. Longer front UCAs and LCAs with stronger ball joints for a wider track and allow for a better articulation angle.
5. Adjustable chassis-mounted rear anti-sway bar w/ quick disconnects.
6. Adjustable front anti-sway bar w/ quick disconnects.
7. Rear TrueTrac LSD with push-button locker...w/all the computerized traction-control systems we currently have.
8. Optional front push-button locker.
9. Bigger wheel wells to allow for larger tire diameters without a lift.
10. 6-piston front brake calipers, 4-piston rear calipers.
11. Optional water 'n mud resistant interior with rubber mats and neoprene seat material.
I know. Not asking for much.
6th Gen Wish List:
90-95% of the 4runner buyers will not care 1 lick of those mods. hence it will never happened
:pop2:
2023 for the 7th gen. It's going to have a twin turbo 1.4L 3cyl Diesel in it. I read it on the internet.
:pop2:
I thought it might be 90-95% of Highlander and RAV4 buyers will not care 1 lick. If you want hybrids, "bells n whistles", nice ride, etc. you don't buy a 4Runner or FJC. Why else buy a 4Runner or FJ Cruiser but to have superior off-road capability? Sport Utility Vehicle...make it so.:vader:
The 2023 7th Generation 4Runner:
-Now Smaller!
-No nasty BOF
-FWD for best MPG!
-3cyl GDI (Turbo is only in the Sport models)
-Optional P175/65R16 (24.9" almost 25" tires! WOW!) All Terrian tires, (Factory is P175/60R16 [24.2"] so you know its a big improvement!)
-Whopping 5.3" of Ground Clearance!
-26.4ft Turning Radius for those tight lightly dusted streets
I'll try to keep mine realistic as possible. We have gone rounds about diesel before, so I'll go in a different direction towards power and fuel economy.
First a 6 + gear auto with Toyota reliability.
Second, a new engine. While the one we have now is adequate, I would like more. So either a V8 with active fuel management, direct injection, start/stop, etc. basically whatever it takes to get improved fuel economy OR...
A engine similar to Ford's new 2.7 eco boost 6-cylinder... Iron graphite block, 325hp/375tq... And giving the heavy F-150 18 combined and 23 + in some reported highway mpg. Now those numbers aren't too much higher than what we have now, but I'm pretty sure even with aluminum the F-150 is heavier, and even if mileage was the same that's a huge increase in power and torque.
Everything else seems to be incrementally improving on its own, the power train while reliable seems to be the weakest part of the package.
Honestly, I'd be happy with the following:
- Restyle the limited to look like the TRD OR
- Add 2WD option for dry road highway cruising
- redesign/replace the entune with something which supports android audio
- a 6/7 speed tranny
- retune the sluggish brake pedal feel/lethargic acceleration
- have a beige interior option (if you ever owned a long haired german shepherd you'd understand)
and I'd buy 2 to last me till my dying days.
Every weekend I drive my 4th gen 4runner with 140k miles on it, I realize how much I miss it. But I need a daily driver.
I took out my 2018 for a spin in the snow on local NJ roads last night and while it performed well, every time I had to make a sharper turn I cringed whenever the wheels made contact with the dry pavement and I could feel the system strain.
5th gen only has full time 4wd on the Limited, the other two models can be left in 2wd. Also Beige interior is available on all trims except TRD OR and TRD Pro
My wishes are modest:
1) Bring 2010-2013 Trail trim back
2) Keep 4.0 V6, but add DI (should give it another 20-30 HP and 20-30 foot-pounds of torque)
3) Add 6 speed Auto and possibly 6 speed manual.
IMHO: if above is done, 6th gen 4Runner is good for another decade… LOL.
