2021 4Runner OEM LED Headlights/Lights Performance and Retrofit
uhOh50,
I don't believe anyone has found a way to properly do so yet in the pre-2022 4runners.
I already answered your previous comment about utilizing the high beam function of the Bi-LED headlights in previous posts. I am able to run my DRL with the high beam halogens and activate the Bi-LED high beam and halogen high beams.
Let me see if I understand this, please correct me if I have this wrong.
-You have a 2020 Pro which originally had the halogen low beam / halogen high beam.
-You bought and installed the 2021 Pro headlights that are LED hi beam and LED low beam (bi-LED).
-You de-pinned the plastic LED low beam connectors from your old original headlights in order to install them on your new bi-LED headlights.
-You took out the 3 pins from each new bi-LED headlight connector, then installed the red (pos) and black (neg) into the old low beam headlight connector in the proper positions.
-You plugged your truck’s low beam harness into the modified bi-LED headlight connector.
-You plugged your truck’s high beam harness connector into a 9005 bulb installed in the bi-LED headlight’s (former) DRL position.
-You wire-tapped or soldered an additional length of wire to the blue pinned wire of each new headlight, then connected (soldered or tapped) it to the high beam power wire at each respective high beam harness connector (green wire right, black wire left).
-You disabled the DRL function on the entertainment screen.
-So now you have LED high and low beams, and the halogen reflector lights up as a high beam also. And you have no DRL function.
Is this what you did?
Electroboy,
Correct except the connection to the high beam harness. I wanted to retain my DRL function and have both LED high beams and halogen high beam functional.
I tapped power off the green wire right and black wire left off of the high beam harness by stripping back enough insulation to solder to the respective wires. that tapped wire was connected to a bosch style relay with a diode for spike suppression to terminal 85 and 30. Terminal 87 was connected to the blue Bi-LED high beam actuator and terminal 86 was ground.
I utlitilzed a bosch style relay because the voltage needed to activate the relay is around 7 volts. The voltage output of the green and black high beam power is low around 2-3 volts in DRL mode insufficient to activate the relay. The relay has a slight humming sensation because the coil is being charged. When the high beam is activated, the voltage output from the green and black wires is 12 volts activating the relay and powering the blue actuator wire.
Electroboy,
Regarding disabling the DRL via the infotainment screen - this is not possible with the old entune on the 2019 and below 4runners.
That is true. with early versions, you would need to bend the pin in the drl module. that topic has been thoroughly discussed.
I did not disable my DRL function. That is the reason why I am running a relay to activate the Bi-LED high beam actuator.
Got it. Appreciate the insight and will definitely help others.
I am content with just the halogens as the dedicated DRL/highs. But nice to know that it is possible to implement the highs from the LED projectors if wanted.
Just picked a 2022 4Runner. First thing I noticed is these led headlights get super bright whenever the road is not flat. My wife was driving the 4Runner behind me and I’m in a Nissan Rogue. Every changes to the road surface and those led are blinding me. Super annoying. Can’t imagine what the oncoming drivers are thinking. On the bright side (LOL), they light up the road nicely.
For those that are wondering, it is possible to get the halogens to function as a high beam. i just did it tonight on my 2022. I didn’t take any pictures but Ill try to explain it as best I can. Im sure there are better ways to do this but this is what I did and it worked.
I disconnected the factory Wiring to the halogen bulbs and plugged in a 9005 pigtail on each bulb. You can find these on Amazon or at your local parts store.
I then connected the wires together on the pig tails. Extend both the positive and negative wires from the passenger side and run it to the driver side. Twist both positive wires together and insert into one end of butt connector and crimp it. Twist both negative wires together and insert into one end of a separate butt connector and crimp.
Next find the headlight harness. Its to the left of the halogen bulb. Youll see a plug with three wires. Black, white and black, and blue. Use a vampire tap and connect it to the black wire.
I then wired in a relay
Pin 30 goes to battery (don’t forget to use an inline fuse)
Pin 85 goes to ground.
So find the negative wire from the pig tail. There should still be one end of the butt connector where a wire can be crimped. Run a wire from pin 85 to the other end of that butt connector. Dont crimp it yet. Next Find a suitable ground and run that wire to the butt connector. Twist both these wires together, insert into the butt connector and crimp.
Pin 86 goes to the vampire tap attached to the black wire in headlight harness
Pin 87 goes to the other end of the butt connector attached to the positive wires from pig tail.
If you were able so somehow understand my instructions, your halogen bulbs should come on when you activate the high beams.
I had to adjust my buddies OEM LED housings down a bit as well. Seems as though they're aimed too high from the factory, at least his was.
I'm one happy guy after installing some ORP LED low/halogen highs on my 2017. I had tried some drop in LED bulbs in the stock housing before and they were lousy.
392197d1643771695-texastjs-2017-t4r-trd-pro-cement-zoe-f7c49712-170f-4659-a264-e7f01b07f357-jpg
You installed the Toyota 2021 OEM headlights?
Can you post the part numbers? Thx.
could you post a picture with the fog lights you have too both views looking out and oncoming. Congrats on the upgrade to LED, one of the best upgrades I did. Next one is hopefully the OEM head unit in the 2017 but that might take some extra work.
Was this install difficult? Have a 2017 Limited Ive been looking to do this to for ages and keep backin out.
Very easy install, it took maybe 30 minutes if that and that was taking my time. Removing the front bumper is simple and headlights are just a few screws. If doing I would recommend installing LED fog lights as well. Would recommend marking off the current headlight cut off light height from about 20-25 ft and use that a marker to set the LED height.
There is a DIY on the pin swap in this forum to help with install.
It's pretty easy, I didn't completely remove the front bumper because I have a hidden winch mount and didn't want to remove the fairlead. I recommend completely removing the bumper. 4 wheel well screws per side (?), unplug fogs from below, pull the bumper off. 4 more screws per side to remove the headlight assemblies. Remove the connector from all 4 housing, then attach the 2017 connectors to the 2021 housings (no splicing/wiring). Plug the new headlights in to make sure they work before reassembly. If they don't, switch the two wires in the connector and try again.
Yes that video is good. DRLs still work.
Diode Dynamics SS3 Sport yellow fogs. The sports have a good amount of usable light as fog lights, if you're looking for something to really project the light, I'd recommend Pro/Max and a different beam pattern.
392196d1643771687-texastjs-2017-t4r-trd-pro-cement-zoe-6532aec9-37cd-498a-8380-6fdaeea53252-jpg
392199d1643771713-texastjs-2017-t4r-trd-pro-cement-zoe-435e0977-3061-477f-9b91-d6b7c5ca8aba-jpg
Best upgrade to the Runner. I purchased a new set of 21 led headlights from a member that had the halogen drl/hb and upgraded connector. I think he got them from someone who converts them in Colorado. I installed them and transferred my xenon depot led hb with drl drivers and they have been perfect! Also installed oem led fogs and work great and all match.
thanks for the pictures, Im debating it still. Would probably be pro white color one to match headlights. I leave them on all the time, how was aiming them?
You can always swap lens colors, although a bit expensive at $60 a pair. Aiming is simple enough. You loosen one allen head bolt on each side of the housing (reach from underneath), aim it, and retighten both bolts. Repeat for other light. I leave mine on all the time as well.
Jhunt
