Too Stroked
Member
Sport, Pro, or Max ... which is recommended as a replacement fog light?
Based on personal experience with the Pro and Max fogs in selective yellow, here's my thoughts.
The Sport is probably the biggest bang for the buck. It provides more than adequate lighting and properly aimed, won't bother anyone. If you run your fogs all the time, this is the one to get.
The Pro is more powerful, but has a slightly less well defined beam pattern - particularly the height of the horizontal beam. This shows up as more "up light" which gives somewhat more distance projection, but also may bother oncoming drivers occasionally - even when properly aimed.
The Max is stupid powerful, yet still street legal. The beam pattern is much tighter than the Pro and in fact looks a lot like the Sport pattern - just brighter. They're totally awesome, and ridiculously expensive. They also require the most careful aiming so as not to bother oncoming drivers.
