255/75/17
paraordnance
Will this size fit OE 17" rims? I'm looking for some tires here and the one I want either comes in 255/75/17 6/C or 265/70/17 which is 10/E rated. I affraid E load rating is way too much for 4Runner and ride will be too harsh. They $200 more for set of 4 too. So I'm leaning to 255/75/17 will they fit stock 17" wheel? Thanks.
Stock Tire - 265/65R17 >Search Tires Tire 2 - 255/75R17 >Search Tires
Section Width: 10.43 in 265 mm
Section Width: 10.03 in 255 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7.5 - 9 in
Rim Width Range: 6.5 - 8.5 in
Overall Diameter: 30.56 in 776.22 mm
Overall Diameter: 32.05 in 814.07 mm
Sidewall Height: 6.78 in 172.21 mm
Sidewall Height: 7.52 in 191.00 mm
Radius: 15.28 in 388.11 mm
Radius: 16.02 in 406.90 mm
Circumference: 96.00 in 2438.4 mm
Circumference: 100.6 in 2555.2 mm
Revs per Mile: 680.6
Revs per Mile: 648.9
Actual Speed: 60 mph 100 km/h
Speedometer1: 57.2 mph 95.3 km/h
Speedometer Difference: - Speedometer Difference: 4.885% too slow
Diameter Difference: - Diameter Difference: 4.65%
Thats a 32" tire, will they even fit NOT lifted 2004 4Runner?
Yes, they will fit fine. This might be the size I go with for my next set of tires.
E rated tires will ride like a dump truck. Unless you carry excessive weight, don't get E.
Several happy campers with that size. That's the size I will use next:D
The BFG MudTerrains went on sale a while back, $100/tire. Several folks jumped on that deal...
A couple of guys have had the 255/75 BFG MT's without a lift. IIRC no issues or very minor fender relocation. In both cases it was short lived because they upgraded to a lift. Spaceman had 275/70/17's, no lift with minor rubbing. The 255/75 is the same height and narrower.
:cheers:
:cheers:
Excellent, thanks.
More people are coming out with that size.
I know FS Dest AT has it out , BFG MT has it ...... who else makes that size ?
You can have:
-BFG Mud Terrain
-Firestone M/T
-GY Mud Terrain MTR
-Toyo Open Country A/T
-GYSA (P or LT-C maybe... I have seen the LT-C referrenced but never seen one in real life, I have only seen the P.)
-GY Triple Tread Fortera
-GY SR-A (not of much interest to many but if you want a 255/75/17 spare they are very cheap)
-GY Fortera Highway
-Dueler Alenza
-Dueler D695
-RevoII (LT-C)
-Scorpian STR A (Street tire)
-Mich Latitude Tour
-Firestone Destination A/T
-ContiCrossContact LX (highway tire)
-Hankook A/T (Toyo/Nitto A/T look-a-like)
-Hankook M/T
I am sure there's others...
Thank-you Jeep:dancin::D
:cheers:
Depends on a tire brand. After a lengthy research I came to conclusion that 265/70/17 Firestone Destination M/T will not fit without a lift and barelly fits with 3/2 and 1.5" BL so dont even attempt it on this tire. 255/75/17 yet slightly bigger.
265/65/17 is stock tire size.... 265/70/17 tires fit on STOCK suspension. I think you may be mis-informed.
not, I'm not mis-informed. As I said tire of a same size from every manufacture is in fact will be very different with actuall measurments depending or M/T vs All-season etc. Go see it in person, I put OE Cross Terrains beside 265/70/17 Destination M/T and Michlens are WAY smaller.
On pictures bellow shown 265/70/17 Destination M/T with 3" Toytec Ultimate lift and 1.5 BL. Please dont tell me these same shoes will fit without a lift. I'm not talking width here, I'm talking overall ACTUAL (not claimed) diameter of a tire.
DSC_0008.jpg~original
DSC_0011.jpg~original
DSC_0014.jpg~original
DSC_0104.jpg~original
and here the AT tire in 265/65/17 for comparison
DSC_0003.jpg~original
I have 255/75/17 BFG mud terrains they were on before my leveling kit and fit fine front and rear
I just put my 255 75 17 BFG Muds on my 4runner and they fit fine WITHOUT the lift. However i do have a daystar lift on order.
For those that claim to have no issues with 255/75/17, have you guys confirmed this when the suspension is flexed (aka off-road or up a high curb)?? Just wanted to clarify it for future members.
