255s Versus 285s: Facts Over Fashion
spectre6000
For some reason it seems 285/75 tires are far and away the most common tire people aspire to put on their rigs regardless of an individual's actual driving habits, conditions, etc. This completely confounds me. Cars are not an inexpensive hobby, and it seems silly to waste money like that (not only on the tires themselves, but the related repairs and modifications that result). The subject of 255s/285s subject has come up in a number of threads here lately, and I feel most people are basing their decisions on these sorts of things based on aesthetics, W-esque feelings, and "what Bobby-Joe did" rather than anything all that objective or substantial... Hopefully it's for lack of information rather than such poor decision making.
For starters, read this article. It's not a blog, not a sales piece, not some random guy's post on some random forum, it's a fairly well written and researched white paper. If you need help understanding anything in the article, this link and this one will probably come in handy.
The best tire for a given rig is dependent upon where and what that rig will be doing its thing (and definitely not what other people in the area or on your favorite forum are using). If you wheel mostly in sand and mud, yes a wider tire is probably a better bet. If you wheel just about anywhere else (to include mall parking lots) the narrower tire is better.
The standard theory on tire size as I've seen it stated in the myriad discussions on the subject is that wider tires provide better grip because the tread covers more square inches. This is excellent justification for a wider tire IF your surfaces you're getting traction on are smooth and regular like tarmac. The alternate side to that theory is flotation; this applies only to smooth regular surfaces that are soft like sand or mud and deep enough that cutting through does not provide the greater tractive force. These are the ONLY instances in which that theory holds water.
Most of us, however, do not do our wheeling in deep soft sand and mud, we do it on rocks and sticks and dirt and such. These surfaces are hard and irregular, and do not require or benefit from any sort of flotation or distributed surface area (you're only going to be contacting the highest spots). If you read the white paper (the link), I don't think you have to get through more than the intro to see the point illustrated that a narrower tire grips these few high spots BETTER than the wider tires at the same pressure.
When wheeling you air your tires down not to increase the footprint of the tread, but to allow the tire to conform to the terrain and "grip" it. The paper uses the more appropriate term "mechanical keying". A narrower tire aired down and compared to an identically inflated wider tire will grip the available terrain BETTER than a wider tire due to the exact same effect as the flotation advantage had by the wider tires in soft terrain. Since the load on the wider tire is spread out more, it can't grip the available grippy spots as tightly (because that grip is spread out over more potential grippy spots) as the narrower tire.
Think in terms of specific scenarios:
A big rock:
Smooth, rounded, probably some sand or something dusted over the top
Advantage: draw. Unless the big rock is really big and really smooth, they're pretty much going to be contacting the same area
A bunch of smaller, but still decent-sized rocks:
Jagged, irregularly distributed, firm
Advantage: skinny tire. The narrower tire grips more firmly on fewer points as it deforms over them than the wider tire which is "floating" (borrowing the term) more loosely over the top of several rocks with less overall deformation.
Hard dirt:
Distributed, gives some but not much, irregular surface, will displace
Advantage: skinny tire. The narrow tire will, for the same reasons as the smaller rocks scenario, grip the parts of the terrain that are firm. Where the terrain is loose, the narrower tire has a better chance of cutting through to the more firma terra.
Slick Rock:
wide, generally flat textured surfaces with gentle curves, firm
Advantage: kind of a draw really... It's like driving over sand paper. You could pretty easily get by with just about any tire. It's called slick rock because it was slick for horses with their shoes and the hard wagon wheels, not because tires didn't stick to it like glue.
Mud:
Mud
Advantage: Depends on the depth... Narrower tire wins if the mud is shallow, wider if it's deep and soupy.
Sand:
sand
Advantage: see mud.
Snow:
snow:
Advantage: wider is better for deep snow to stay on top, narrower is better for less deep snow to cut through to the grippy terrain.
I'm going to go ahead and stop with the scenarios. Apply the logic to whatever you want.
If you use your 4Runner for anything other than occasional (or even regular) wheeling like, I don't know, a general mode of transportation, the narrower tires are better period. Better fuel economy, larger tires without body modification, etc. All those reasons stated a million times elsewhere. If your rig is built for extended adventure travel (long, unsupported trips over any and all terrain), you're generally better off with the narrower tires as they're better suited for a wider variety of uses. If you just want it to look cool in the parking lot with the tires sticking out, get the wider ones and try this forum for future postings.
Not going to argue with the things you posted, most of it is probably true. But I'm not a fan of you calling out all kinds of people for what they choose to do with their money to their trucks.
You've been member here for 5 months, long enough to know there is a large, diverse group of owners. But not long enough to tell people that if they want to run 285s they need to go to another forum. I am not going to get 255s because I don't like the look. I drive mine very day, I want to like the look of what I drive.
If you can't appreciate the work people put into these rigs, whether is justifiable by you or not, you can ****ing leave.
A) get off your high horse. You picked a different size tire? Oh wow you must be so sophisticated..
B) Insulting people who choose a different size tire than you is just stupid and ignorant. Not everyone wants ugly ass pizza cutters. Why don't you try this forum, its more douche friendly.
Yeah most people choose 285, I did. You know why? Its a common size and its cheaper. You can find any tire you want in a 285, not many make 255s. It is a well proportioned tire for these trucks, 255s look re****ed on 4runners. Yeah, 285s look a lot better and you're a damn liar if you say you have never cared about your truck's appearance.
The offroad advantage of 255's is blown out of proportion, driver skill is far more critical and has more of an effect. I have wheeled with lots of guys with 255s and I did better than them most of the time.
The one and only advantage I see is the increased fuel economy, and seeing as I easily get 19+ consistently as it is, I don't see that as much of an advantage either.
Good posting, Millerad1651 and Ripcord!
This guy was driving a VW bus 6 months ago. He moved to CO and now he's an expert on 'Wheeling, and a self proclaimed tire expert, all because he can regurgitate and reiterate what he read on various websites about the advantages of one tire size over another.
This is also the guy who thinks all people who perform the deckplate mod are idiots, and that the rear differential breather must be extended up the D-pillar in order to be truly effective.
This thread and its author just have an air of "talking down to people" about them.
Speaking of which, I ran with my deckplate in for a week just for sh!ts and giggles. Felt like a damn snail, throttle response went down the crapper and the power band felt like it changed. Took it out and bam, back to the same old zippy little truck I know and love.
Sorry if I hurt your feelings. I feel pretty safe in speaking from the point of view wherein mallcrawlers and other "looks cool" over "works" decision making aren't really in keeping with the nature of the forum. Am I mistaken in this observation? That's not to say things like LED tail lights, Satoshi grilles and other purely aesthetic choices don't have their place, they absolutely do. They don't hurt anyone or anything and are a great way to personalize one's truck. 285s are popular, and in some (limited) applications better than the regularly posited alternative, but there simply aren't a lot of dune runners or mudders on here (if you are one, your feelings shouldn't be hurt if you read the OP). Regardless, facts is facts and physics isn't a suggestion. Mayhap I'm not the most tactful at times, but there is a lot of misinformation on this forum that is completely wrong and often harmful. This is a place where people come to learn about 4Runners when they don't know about maintenance, taking them off road, etc. If I hurt someone's feelings that gave bad advice or didn't do their homework and made a bad decision at least I'm not compromising safety, causing them to spend money they don't need to spend, or giving generally bad advice that might cause someone to unknowingly miss out on enjoying the hobby as they otherwise would if properly informed.
You're right that I'm new to 4Runners in the last 6 months and was previously driving a VW. I've driven a lot of cars, not many of them all that recent. That's why I don't talk about things like ECUs, fuel injection, anything about any sensors, or anything else that I don't actually know. Tires are tires regardless what they're on and the same rules apply. Are you insinuating tires on VWs adhere to a different order than 4Runners? What about Porsches, Mercedes, Singers, Jowetts, Nashes, etc.? If I went from a downhill bike to a touring bike would that negate anything I said about helmets? I never said anything about the art of wheeling, just tires and their application therein. Textbook stuff that anyone could find themselves if they looked. The problem is that this is where people often look and there is a TON of misinformation and bad suggestions.
Cheaper? Try this and this.
Maybe I'm wrong and form over function is more popular than I thought. It's entirely possible I gravitate toward more substantial threads and have missed the majority of the fluff. I retract.
Well it's a good thing you showed up nearly 10 years after this forum was started to warn everyone from ruining their trucks with bigger tires. I can go to sleep better tonight knowing my truck won't fall apart going down the ****ing highway because I put skinny tires on it.
What do you mean "looks cool over works"? More like "looks cool and works over looks like sh!t and works marginally better."
its called having your cake and eating it too. Some people call that good decision making..
And that misinformation you speak of comes from you. Just becuase you have an opinion does not make it fact.
4750
spectre6000, you sure like to talk about feelings alot, are you a woman?
Like you did, right? And now you think you're an expert, because of this forum? Ha! That's awesome.
You sure are doing alot of "calling out" there... You're a "google engineer" at best. You see a thread, run out and google the topic, come back and regurgitate whatever you agree with.
Try this.. Get your hands dirty and bust up your knuckles modifying your truck... then go out and actually wheel your 4Runner so you have some ground to stand on... finally, spend some time on the forum and get a feel for the members before you attempt to summarize what it/they are all about.
x2 on all that. BFAD, your responses are always so much better worded than mine haha. We can always count on you to say when we are thinking but can't type.
Since you edited, I thought I'd comment on this....
Consider your own post, from both your introduction and your build thread:
Until Tuesday evening this past week, I drove a '62 VW Bus. Due to my recent move to the high rockies, the two wheel drive combined with the thin tires, carburetion + extreme daily altitude changes, and lack of any sort of safety features to handle winding canyon roads in the cold weather wasn't going to cut it.
I get the impression that you didn't like the way the skinny tires performed on your VW (on your gravel driveway, where you got stuck due to your skinny tires, IIRC), but here you are advocating them on 4Runners... I'd say you are insinuating that tires on VWs adhere to a different order than 4Runners.
I'm sure you have a great argument for why your VW needed wider tires, though.
The best rigs on this forum display a harmony between form AND function. True story... People don't have to choose between one or the other.
And Rip, You and I both know that there are people (cough, cough Dr, cough Caffienated Drink, etc.) who would agree w/Spectre and his approach to communicating with people. Fortunately those people are few and far between on this forum.
On the other hand, the vast majority of us manage to remain respectful, speak from our experience, and agree to disagree when necessary. The internet is full disagreement... my beef here is not what's being said, but HOW it's being said.
Dr. Douche is the first person that came to mind when I read this thread...maybe they're brothers! It's one thing to share your opinion, but another to be condescending and demeaning to people who obviously spend time and hard earned money making their trucks the into te vehicle they want. Not everyone wants to drive a 4Runner Panel van with pizza cutters. That's why there are numerous options for us, and numerous variations that people have gone with.
Another X2 on what BFAD said. "Google Engineer" now that's a classic..
I didn't know I had Flotation tires on my Runner...Dayum.
plus it sounds like the Toyota Engineers screwed up by putting 265 stock tires on the Series 3 Runners.
I'm relatively new here as well, and even though I have had issue recently with how Spectre6000 chooses to express his views, I still don't think we should be telling him to GTFO.
Spectre6000: you seem like an intelligent guy and I agree with alot of your viewpoints, but when it comes to expressing an opinion you need to be more tolerant and not try to cram it down peoples throats. There IS room for disagreement, and there just might be things you haven't considered, and you need to deal with that politely.
I look forward to your continued participation.
Wow, y'all are a hostile bunch. I almost thought I was on the wrong site. Opinions are like a-holes, everyone's got one!
I personally can see the logic behind 255 vs 285, but that's not relavent any more. I didn't care to read long enough to dig into any forum-member bashing from the OP or those who replied; nor would I have taken any one's tire preference personally. Whatever, they are effing tires. Get over it. BTW, this is a quazi-public forum and you chose to engage in the discussions, not the other way around.
Also, as I have come to learn, most of you are engineers, engineering students, or in some line of technical work... please use your "engineering judgement" when considering "mods"
They are just that, MODIFICATIONS.
Until you're actually ENGINEERING an improvement, it's just an opinion. And as they say, "in god we trust, all else bring data."
Please don't turn this forum into a hate festival of d-bags bashing d-bags.
Wow...
When did this place turn into Pirate, I am surprised at how some of you have lashed out onto this guy
Yea he is very convinced 255's are the way to go, but didn't see him make any personal attacks, which some of you were very quick to go to.
Here I tell you what
THIS is what you can do, and that's all, we don't need any variation
-285/75/16
-Toytec Lift
-Deck plate
Anything more than that, and Jesus christ are you pushing the boudries
His first post was a personal attack. Saying if we want to put 285s on our mall cruiser then we should just start posting on Tacoma world!?!
I got pissed because he basically said anyone putting 285s on a 4Runner is a moron and doesn't belong here, and is destroying their truck.
Not everyone agrees with the mods people do to their, and the majority don't create long threads bashing them for it either.
It's not that he has a different opinion, its that he was condescending and bashing people with other opinions.
"If you just want it to look cool in the parking lot with the tires sticking out, get the wider ones and try this forum for future postings.
and it seems silly to waste money like that (not only on the tires themselves, but the related repairs and modifications that result). The subject of 255s/285s subject has come up in a number of threads here lately, and I feel most people are basing their decisions on these sorts of things based on aesthetics, W-esque feelings, and "what Bobby-Joe did" "
I'd say it had it coming to them.
I don't have any interest in telling them off myself, because I can make my own decisions about my truck, without their opinions that comes across in a way that reads like a put down.
Who the heck is Bobby-Joe anyways? I've never seen them post anything?
DJNutshell
