If im running 265/70/17 and say i have a blow out and i have a 265/65/17 spare is that to big of a difference in size to screw anything up?
I thought may be ok as long as it is on the front and not in 4wd or is that even nessisary?
Thanks guys..
This was discussed a long while ago. IIRC, the concensus was...
If you have a V6 4WD, you can put it in 2H and put the 265/65 spare up front. Alternatively, you can lower the tire pressure of the 265/70. I'm not sure how low of a pressure the 265/70 needs to be to match that of the 265/65 and avoiding damage to the 265/70 due to low pressure. It's a bigger issue for the V8 4WD because they're always in 4WD.
Instead of re-posting the info, most if not all the answers can be found in this thread: http://www.toyota-4runner.org/perfo...ore/194-before-up-sizing-your-tires-read.html
Kind of along the same lines. Though its never been driven on, the spare is in atrocious shape. The truck is an 04, but I suspect the spare is older than that. I'm not sure what my next set of tires is going to be, as I just replaced my CTs 20k mi ago. I would like to put a CT on the spare again, but 200 bucks is a lot. I've also been scoping out some 'newer' used tires. Will there be an issue with mixing up the brand of my spare? What if I get a spare with a more aggressive tread, like 'revo' not 'BFG K/O' than my CT's?
My spare is not in my rotation plan.
Thanks guys
Bump to get my question answered
Not questioning the collective wisdom here, but why would the offsize spare go on the front? Seems like that would affect turning and handling more than in the back?
