Caliraisedled
Official Vendor
Cali Raised LED 4Runner Rock Sliders: 4th, 5th & 6th Gen (updated Nov 2026)
Jake from Cali Raised LED here. This thread started back in 2018, so here's the current lineup in one place. Ask fitment questions below and we'll answer here.
Two styles
Trail: https://caliraisedled.com/products/trail-edition-bolt-on-rock-sliders-for-2010-2024-toyota-4runner
6th Gen (2025+)
Trail: https://caliraisedled.com/products/trail-edition-rock-sliders-for-2025-toyota-4runner
4th Gen (2003–2009)
caliraisedled.com
Pricing starts at $909.99 a pair. Questions: reply here, call 888-385-5036 or email [email protected].
Older photos from the original 2018 post:
Options explained
Kick out or no kick out?
Kick out angles the back of the slider out, in front of the rear tire, so the back of your truck doesn't get pinned on rocks. No kick out runs straight for a clean look. Same price either way.
Which finish should I pick?
Raw steel: bare steel that will rust if left uncoated. Paint or coat it right away. Powder coat: black, ready to bolt on. Bedliner: offered on the slider for 4th and 5th Gen. On the 6th Gen it's offered on the filler plates only.
Do I need filler plates? (Step Edition)
Filler plates (also called top plates) are optional. They fill in the top of the slider for a flat step with better footing, and come in raw steel, powder coat or bedliner. Skip them for an open tube look.
Threaded or not threaded frame holes? (6th Gen 4Runner)
Before you order, find the 8 mounting holes on the outside of each frame rail and look inside one. Threads inside: pick Threaded, and our bolts thread straight into the frame. Smooth hole: pick Not Threaded, and we include the extra hardware to mount it. No drilling either way, and the price is the same. Not sure? Contact us before you order.
Popular setup: Kick out, powder coat slider, bedliner filler plates (Step Edition).
Two styles
- Step Edition: 0-degree flat top that works as a real step. Top/filler plates are optional.
- Trail Edition: 20-degree angle that tucks tighter to the body for more clearance. No top plates.
- 1.75" DOM tubing, .120" wall
- Frame-mounted with Grade 8 hardware, full gusseting
- 100% bolt-on, no drilling or cutting
- Kick-out or no kick-out
- Raw steel, powder coat or bedliner (bedliner on the slider for 4th and 5th Gen; 6th Gen has bedliner on the filler plates only). Coat raw steel right away.
- Fabricated in-house in Fort Worth, Texas
- Free FedEx Ground to the lower 48, two boxes, no freight appointment
- Fits KDSS and non-KDSS.
- Limited and TRD Sport: only after the X-REAS system and side moldings are removed.
- Step: about 100 lb per set. Trail: about 90 lb per set. Install about 1–2 hours.
6th Gen (2025+)
- Pick the frame kit that matches your truck: most 2025s need "No Threaded Frame Holes", and 2026+ have threaded frame holes. Check your frame, or ask us.
- Step Edition: about 100 lb per set (Trail Edition about 90 lb), about 1–2 hour install. There's an install video for each frame kit on our YouTube.
4th Gen (2003–2009)
- Step and Trail Edition. Fits the Limited and other X-REAS trucks once the X-REAS lines are removed. Not for the Lexus GX470, which has its own slider.
Step Edition Bolt On Rock Sliders For 2003-2009 Toyota 4Runner
Shop Step Edition bolt-on rock sliders for 2003–2009 Toyota 4Runner. Optional top plates, DOM tubing, bolt-on install, and trail protection.
Options explained
