275/65/18s Installed!
Thanks a lot, I totally agree!
Yours looks great man!
Thanks for the ride Stamper!!
You got it buddy, anytime! I'll probably need one friday.
Plus you'll be my go to guy for parenting advice over the next couple years anyway so we can call it even ha ha
So you can actually fit 275/65/18's with only a 1" budget boost and spacers? Did you have to trim? I don't remember seeing you mention anything.
I thought 265/65/18's were the limit for that small of a lift.
I'm trying to decide on what size of silent armors to get, also looking to get budget boost daystars.
I think 265/65/18's will fill my wheel well nicely. 275/65/18's are only 10 millimeters wider and something like 1/4" more sidewall? am I right?
What? I see that you don't have mud flaps but I just got 265/65/18s installed on mine and it's rubbing while turning. I have 5100s set on the 2nd level - which gave me about a 1.5" lift and spidertrax spacers. It made a pretty bad sound when reversing and turning. I just did JAs fender mod to get rid of the rubbing. The driver side just rubs slightly on the mud flap.
If you turn your wheels you may see that the tire rubs on the front fender.
Now that i have larger tires on my 4R, it doesn't look lifted again.
Btw, nice clean looking 4R! Have you ever think about blacking out the middle of your grill? I think it would look pretty good.
I did notice a bit of rubbing on the right side yesterday backing out of my driveway and turning. I know the installer trimmed a tiny bit off of the black plastic on the drivers side, but not much.
And yes you are correct I have the 1" budget boost and 1.5" spacers, that's it.
Rubbing a little doesn't bother me, I had an S60 R where that comes standard along with a turning radius equal to that of the USS Missouri.
Do you mean the 1/2'' (1'' net) front spacer only? Or do you mean you put in a 1'' spacer which gave you 2'' in front?
- Sent via Tapatalk for Android
Its the Daystar 1" Budget Boost, not sure what that nets in the front. The 1.5" spacers are on all 4 wheels.
peacefulpiranha
