275/65/18s On My Limited?
Husker Z
OK, I'm getting new tires and decided on the Terra Grapplers. Problem is, they don't offer 265/65/18s. Question now is, can I put 275/65s on my limited with my spacers and my 1" Daystar budget boost?
Anyone? Looks like it would go from 30.7 to 32.1 diameter. Seems like I might have to trim the wheel liner, at worst.
im sure 275 would be fine stock with a 1 inch spacer lift you should be golden i fit 315s on my fj with a mere 3 inch spacer lift [comes 265 stock]
Thanks. I've been Google searching stuff and while it doesn't seem all that common, it looks as though it's probably okay.
They should fit with a little effort (such as moving the fender liner forward). I wouldn't expect anything major. Also, search for 275/70/17, it's an identical size that I know several folks are running, maybe that'll help. One that comes to mind is ProMed, he had 275/65/18 Cooper STT's I think. There's a very long thread on his setup with mods (ride of the month thread I think).
Im running 275/65/18 duratracs. I do have fox coilovers front and fox piggy back shocks in the rear for a 3/2 lift with spidertrax 1.25 spacers and total chaos UCA's. I still had to move my liners forward about 3" and trim the fenders a small bit. I think it's going to be pretty tight with a 1" lift but I think you'll be fine.
I think I have time to get them installed next Friday, so stay tuned!
What time do I need to pick you up from kc trends?
goddesszilla
