Caliraisedled
Official Vendor
4Runner Rock Sliders: Step Edition vs Trail Edition, which should you get? (updated Nov 2026)
Jake from Cali Raised LED here. The question we get most about 4Runner sliders is "Step or Trail?" Here's the honest answer.
Get the Step Edition if:
5th Gen (2010–2024) fitment notes: both fit KDSS and non-KDSS. Limited and TRD Sport only after the X-REAS system and side moldings are removed.
Links
Questions: reply here, call 888-385-5036 or email [email protected].
Options explained
Kick out or no kick out?
Kick out angles the back of the slider out, in front of the rear tire, so the back of your truck doesn't get pinned on rocks. No kick out runs straight for a clean look. Same price either way.
Which finish should I pick?
Raw steel: bare steel that will rust if left uncoated. Paint or coat it right away. Powder coat: black, ready to bolt on. Bedliner: offered on the slider for 4th and 5th Gen. On the 6th Gen it's offered on the filler plates only.
Do I need filler plates? (Step Edition)
Filler plates (also called top plates) are optional. They fill in the top of the slider for a flat step with better footing, and come in raw steel, powder coat or bedliner. Skip them for an open tube look.
Threaded or not threaded frame holes? (6th Gen 4Runner)
Before you order, find the 8 mounting holes on the outside of each frame rail and look inside one. Threads inside: pick Threaded, and our bolts thread straight into the frame. Smooth hole: pick Not Threaded, and we include the extra hardware to mount it. No drilling either way, and the price is the same. Not sure? Contact us before you order.
Popular setup: Kick out, powder coat slider, bedliner filler plates (Step Edition).
- You want a real step for getting in, for kids or passengers, or for reaching a roof rack.
- Your 4Runner is mostly a daily driver that sees trails on weekends.
- You want the option of top/filler plates (raw steel, powder coat or bedliner).
- Clearance matters more than stepping on them. The 20-degree angle tucks the slider tighter to the body.
- You wheel tight, rocky trails where a flat slider can hang up.
- You don't need top plates. Trail Edition doesn't use them.
Links
- 5th Gen Step: https://caliraisedled.com/products/step-edition-bolt-on-rock-sliders-for-2010-2024-toyota-4runner
- 5th Gen Trail: https://caliraisedled.com/products/trail-edition-bolt-on-rock-sliders-for-2010-2024-toyota-4runner
- 6th Gen (2025+) Step: https://caliraisedled.com/products/step-edition-rock-sliders-for-2025-toyota-4runner
- 4th Gen (2003–2009) Step: https://caliraisedled.com/products/2003-2009-toyota-4runner-step-edition-bolt-on-rock-sliders
- 4th Gen Trail: https://caliraisedled.com/products/2003-2009-toyota-4runner-trail-edition-bolt-on-rock-sliders
Options explained
