4Runner Rock Sliders: Step Edition vs Trail Edition, which should you get? | Cali Raised LED
Caliraisedled
Official Vendor
4Runner Rock Sliders: Step Edition vs Trail Edition, which should you get? (updated Nov 2026)
Jake from Cali Raised LED here. The question we get most about 4Runner sliders is "Step or Trail?" Here's the honest answer.
Get the Step Edition if:
  • You want a real step for getting in, for kids or passengers, or for reaching a roof rack.
  • Your 4Runner is mostly a daily driver that sees trails on weekends.
  • You want the option of top/filler plates (raw steel, powder coat or bedliner).
Get the Trail Edition if:
  • Clearance matters more than stepping on them. The 20-degree angle tucks the slider tighter to the body.
  • You wheel tight, rocky trails where a flat slider can hang up.
  • You don't need top plates. Trail Edition doesn't use them.
Same on both: 1.75" DOM tubing with .120" wall, frame-mounted with Grade 8 hardware, full gusseting, 100% bolt-on with no drilling, kick-out or no kick-out, fabricated in-house in Fort Worth, Texas, free FedEx Ground to the lower 48.
5th Gen (2010–2024) fitment notes: both fit KDSS and non-KDSS. Limited and TRD Sport only after the X-REAS system and side moldings are removed.
Links
Full specs, weights and install times for every gen are in our main slider thread: https://www.toyota-4runner.org/threads/266181/
Questions: reply here, call 888-385-5036 or email [email protected].
Options explained
Kick out or no kick out?
Kick out vs no kick out rock sliders
Kick out angles the back of the slider out, in front of the rear tire, so the back of your truck doesn't get pinned on rocks. No kick out runs straight for a clean look. Same price either way.
Which finish should I pick?
Rock slider finishes: raw steel, powder coat, bedliner
Raw steel: bare steel that will rust if left uncoated. Paint or coat it right away. Powder coat: black, ready to bolt on. Bedliner: offered on the slider for 4th and 5th Gen. On the 6th Gen it's offered on the filler plates only.
Do I need filler plates? (Step Edition)
Filler plate vs no filler plate
Filler plates (also called top plates) are optional. They fill in the top of the slider for a flat step with better footing, and come in raw steel, powder coat or bedliner. Skip them for an open tube look.
Threaded or not threaded frame holes? (6th Gen 4Runner)
Threaded vs not threaded frame holes
Before you order, find the 8 mounting holes on the outside of each frame rail and look inside one. Threads inside: pick Threaded, and our bolts thread straight into the frame. Smooth hole: pick Not Threaded, and we include the extra hardware to mount it. No drilling either way, and the price is the same. Not sure? Contact us before you order.
Popular setup: Kick out, powder coat slider, bedliner filler plates (Step Edition).
We also got a pair of 4Runner 0 degree sliders powder-coated that are $100 off since it was scratched and dent.
$849.99 Ship to your door
$669.99 Local Pick up.
Please give us a call if interested.
888-385-5036
Here is our Update on our in Stock 5th Gen 4Runner Sliders Cali Raised LED 10/7
20 Degree Bolt on Rock Slider w/ Kick out = 6
0 DegreeBolt Bolt on Rock Slider W/ Fillers W/ Kick out =1
0 Degree Bolt Bolt on Rock Slider W/ Kick out =2 & 1 powder-coated at a discounted price!
10/23
We have 5 pairs of everything raw IN STOCK Ready to ship!
Contact us today and one of our team reps can gladly assist you. We will be updating this thread weekly! 888-385-5036!
2014-2020 Toyota 4Runner Rock Sliders– Cali Raised LED
Installed your light bar and behind the grill mount on my 4Runner a week or so ago. Looks / works real good. Really lights up my road.
Now I need a patch for my headliner. The Eibach patch is looking lonely up there.
Just an FYI, your location still says California. They are now in Ft. Worth so if you are in the DFW area shipping is free! Just go by and pick them up.
Jhunt
