285/75/17 -38 offset runners. POST image please
88maroon
Where are my guys with 34s running 285/75/17 with negative 38 offset with 3inch lift? BMC, front fender trim, what else?
It'll be close. The wheel offset is a problem. I'm not sure if it'll clear the body mount area. You'd have to test with your alignment to see. I ran that size tire with 1" wheel spacers on stock TRD OR wheels. Net was effectively about a -10 offset wheel. They had no issues clearing with a BMC and forward alignment. They clear better with no lift because the stock UCA is further forward and the net alignment maxed out forward and stock UCA has more clearance than a lift with aftermarket UCAs. I had it both ways. (I played around a lot with various configurations).
All I can say for sure is that if you have aftermarket UCAs and -38 offset - it'll be very close to the firewall pinch weld. Not sure if it'll rub or not. And you'll need to do some clearance work on the front bumper and fender liner for sure.
BFG KO2 285/75r17 on SCS Ray10 17x9 -38
3” lift, BMC, hammered pinch weld, bummer and fender liner trimming
Here's mine when it has 285/75r17 Geolandar MTs, 0 offset wheels with Spidertrax 1.25" spacers; similar to what you're looking for:
And here it is again with 285/75r17 and -25 offset wheels
seltzernator
