I took the headliner out of mine when I built my rack. I did not however take any pix of the inside.
I made front and rear plates - PITA to get the contour correct - then bolted through with large fender washers bit not to big that would cause it to tear the sheetmetal - it is REALLY thin - I used nylocks on the bolts as I didn't want to take it back apart. Then used some 1/4" thick rubber - like mudflap material - between the plate and roof then a layer of Vulcum.
I will tell you it has to fit perfect!!! I was about 1/4" off on the right rear side when the other 3 were perfect, I thought I could just tighten it down......BAM!!! there went the rear side window - it didn't like to be stressed. Adjusted the rack until it was perfect then bolted it down and have about 10K miles on it now with lots of high speed off road stuff.
I made mine out of .120" 1.5" as I wanted to to double as some rollover protection without installing a cage in it.
Not a fan of the roof mounted spare but with the rear work I did I needed up there, I am constantly in the rear and didn't want the spare there everytime I get something out of the back. It also doubles as a shooting platform,
, it supports 450lbs of people regularly.
