2wd front hub replacement
Are you just swapping out hubs or are you replacing bearings? The hub is bolted in but the bearings are pressed in. You can remove the hubs your self then have a shop install the bearing..
*How to* - front wheel bearing replacement - TTORA Forum
You're all sorts of wrong, and that write up is only for 2005 and up.
The Bearing is pressed into the knuckle, and the hub is than pressed into the bearing.
http://www.toyota-4runner.org/3rd-gen-t4rs/87516-aisin-manual-locking-hubs.html
Same principle, you're just not adding the Manual hubs.
Ambrose67
