Ok so update finally! Don’t want to say for sure yet, but things look to be better (in a way; I’ll expand on that in a minute).
Got the FPR in the mail, and set out Saturday morning to remove the old one and replace with the new. I got the Air Intake baffle, TB, Top and Bottom air intake off pretty easily. Just a bit time consuming. I also managed to crack the driver’s side plastic wiring harness cover up pretty good, so I very carefully inspected and made sure to clean any plastic bits up. Stuffed small rags into the intake manifold to keep any crap out. So now I can see the old FPR at the back of the fuel rail on the driver’s side. I could not remove it directly from the fuel rail with the fuel rail in place on the manifold. The little 10mm bolts holding the FPR on were in there GOOD even with PB Blaster and WD-40. I could only access them with a small wrench, and could not apply that much pressure at that angle. I was starting to strip them, so I set about looking for how to remove the fuel rail.
After a bit of Googleing, I saw that you can remove the 4 bolts holding the fuel rail down and lift straight up. It came up, but in the process, I managed to break the front driver’s side fuel injector. CRAP. I lifted the injector up, and saw the small injector head sitting there in the hole. I tried to suction it up, but it would not work. I very carefully tried to pull it out with needle-nosed pliers…and pushed it into the intake manifold. Well, now I had to remove the intake as well to keep the injector out of the valves! After much cursing, I called around and found another injector close by.
I proceeded to remove the other injectors CAREFULLY to avoid breaking them as well. The fuel rail was loose, but still had the primary and return lines wrapping around and through wiring harness and like 4 different vacuum hoses. I was able to get the hoses out of the way, but I really didn’t want to remove the whole wiring if I could avoid it. So, I disconnected the main fuel line from its spot near the charcoal canister. I ended up having to cut the return fuel hose attaching straight to the FPR so I could get the fuel rail out of the engine bay. To remove the FPR from the rail, I had to sit to with the rail in my lap, and wrench at it with a 10mm socket on each bolt with a crescent wrench around the body to hold it in place. Those were honestly the hardest bolts/nuts for this entire project. Got the new FPR on, and now I needed about 6” of new fuel line to replace the bit I cut.
Well, to remove the intake, I had to drain the radiator of coolant. This needed to be done anyways, because I noticed when I bought it that it had orangeish green in it. I already had a bottle of non-diluted Toyota red ready to go.
I got radiator drained, and took the radiator hose and the top timing cover off to allow clearance for the intake manifold. I noticed that the Cam Sensor was very dirty so I sprayed it down with electrical contact cleaner, and then covered the timing belt area with a large towel to keep debris from getting in. I got the Intake manifold off, and found the tip of the injector just sitting there on one of the valves.
I was very apprehensive about trying to reach in there to grab it; I didn’t know if my pliers were long enough. So I held a very bright LED light in my mouth and ‘started playing Operation’. And I did NOT make it buzz! Woohoo!
I had also bought a new PCV valve to replace the old brittle one, and of course manage to break the old one like crazy. Don’t worry, I had another towel covering the intake area. So, I removed the valve cover (after removing the spark plug coil packs.) and started fishing with a pair of pliers. After tilting the valve cover all over the place, I was able to get the old PCV out. I put the new gasket and valve in, applied some new RTV to keep the molded gasket in place, and put the valve cover back on.
Question- how loose are the valve covers supposed to be? These were so loose (all bolts) that I originally thought my socket was too big. When I reattached the cover, I tightened them, but not super tight. On the driver’s side too.
I got the new injector and bit of fuel line, as well has new O-rings for the current injectors. I was soaking the current injectors in gasoline to help clear any crap out.
I got everything patched back up, and was very relieved to see that I had not miss ONE bolt or hose. Haha. I also put some plastic wire loom cover over the driver’s side wire harness by the fuel rail for heat protection.
I filled the radiator back up with distilled water, and added to radiator cleaner. I started it up, and after about 5 seconds or cranking, it fired up! I ran the cleaner + water through until a couple minutes after the heater kicked on, then let it cool, drained the radiator of the roughly 1 gallon, and then topped it back off again with more distilled water. I kept an eye on the temp gauge, and it DID fluctuate a bit, but it never overheated.
I did this 5 times until the radiator was draining clear. Then, added the full 1 gallon of Toyota Red to the radiator. There was already roughly a gallon of pure distilled water already in the system, so this would make it about 50/50. This time, I was STUPID and forgot to top it off. I took it for a test drive around the neighborhood and noticed that the heater was not coming on. As I was at the back of the neighborhood, the temp gauge shot all the way up so I shut it off immediately. I had brought another gallon of distilled with me, so after about 5 minutes, I popped the radiator lid (with a rag just in case), and after 30 minutes or so after that, topped the radiator off with the distilled water. NOT cold; it’d been in my garage for a few weeks. It was hard to start this time, but the heater kicked on instantly, and the temp gauge leveled out to normal. I got home just fine, no more issues. After it cooled, I took it out for another test drive, not just in the neighborhood and no issues at all. No leaks, no significant noises, nothing. I changed the oil filter just in case, and ensured that the oil level was topped off.
NOW, today, I’m noticing something else. It starts up great, and revs a whole lot more easily, so the FPR fixed those issues (I hope), but now I’m hearing a bit of clatter in the engine when in park (around 1100 – 1400 rpm) that I did NOT hear yesterday even after the overheat incident. It does not have a pattern, but is regular. It stops when in moving gear (drive, reverse, etc) when the idle is lower, and I don't hear it when getting on the gas with the windows open. I don’t hear it in the cab, so it’s not SUPER loud, but I can hear it with the hood closed. What does a clattering fuel injector sound like? I made sure to install the new fuel injector in the front passenger side slot for ease of access if the injector was bad, so I can replace it if necessary. I don't have a stethoscope, but it sure sounds like its coming from the new injector. It almost sounds like clattering porcelain dishes like when you bang on the kitchen cabinet or something.
*update* Now, after driving back to the office from a client's, I made sure to drop into neutral and lower the windows at every full stop to raise the RPMs to see if I can hear the noise, and it is definitely decreased. I checked it when I got to the office. Put it in park, popped the hood. The noise is still there, but very irregular. Instead of several times a second, it's only every few seconds; still no pattern. Seems quieter when it's happening as well. Do fuel injectors have a break-in period?
Sorry for the novel.
