3.4 swap?
What I have read that the oil pan is NOT interchangeable for those of us with IFS. I believe you use a T100 pan and pickup with slight modifications or make a franken pan out of your 3.0 stock pan. Somebody chime in to correct me if I am wrong. :hiding:
ORS told me to use my stock 3.0 pan.
Yes I am sure you can but with modification
Which oil pan to use in your 3.4L swap - YotaTech Forums
I think you have to modify because of the dipstick location. the 3.4 is not in the same place and cannot use the same oil sump.
Edit: looks like it can go both ways as long as you have to correct oil pickup and tube conversion???
[MENTION=100733]sam24th[/MENTION] is correct; just make sure you get the right conversion parts!
MaximussK
