3.4l cylinder head install help
vipergrhd
I did search the forum prior to posting and could not find the answer i need,i am reinstalling a set of rebuilt heads on my 99 T4R on Monday and i already know the torque specs and proper sequence. I need info on the MLS gasket if there is some kind of spray/sealer you guys apply to the MLS gasket prior to installing the head and what kind if there is,i did buy the Toyota head gasket set,should i replace head bolts? i did inspect them with a straight edge and no signs of pulling i know for a fact that the head bolts are not TTY so it could be reuse. Thanks for any info.
Always get new bolts. And no sealant I'm aware of. Usually anything like that just disrupts the seal and causes leaks. I just did this two weeks ago so I know that you do not want to redo all this once it's together. Thankfully I had no problems.
seltzernator
