3.4L v6 - Code p0100, p0110, engine starts, idles rough for a few seconds and dies.
Fol
Hey folks - not sure if this is the appropriate place for this but I'm struggling to nail down the problem here - this problem just started 3-4 days ago.
Over the span of an afternoon, I noticed hesitancy in power delivery while driving in the city - and my check engline light popped on. After parking it for a while, and then going for a ten minute drive, this problem had escalated and revving was very rough and hesitant.
After coming to another stop and parking / shutting it off, vehicle will start but idles rough for a few seconds and then dies. Tapping the gas during this will either cause the RPMs to drop, or hesitate and then rev up, and drop again and die.
I've had this 4runner for 11 years - Sitting @ 439,000KM.
Past maintenance relevant to the problem:
Timing belt + water pump done @ 405,000km
Spark plugs done just a couple months ago around 427,000KM.
Fuel Filter changed yesterday - but it had not been changed for many years prior to this.
Fuel pump replaced 2015
Fuel injectors not touched.
Throttle body last cleaned probably 2-3 years ago.
p0110 p0100 codes are IAT sensor / MAF sensor.
I cleaned the MAF sensor without any change in running - same thing, idles rough and dies after a few seconds.
After I replaced the fuel filter yesterday, it did run relatively well for about 2-3 minutes before bogging down and dying.
I am happy to buy a new MAF sensor but these problems seem more complicated than that. I just want to get a little help before I drop 200 on a Denso MAF sensor.
This morning, I went to give it another try and it would not start at all. I gave the fuel tank a hearty whack with a baseball bat and it did start - but the same rough idling. I could get the engine revving a little bit but it still died after 10-15 seconds. This makes me feel like it is moreso a fuel delivery problem and not a MAF sensor issue but I'm a YouTube mechanic who's lacking a lot knowledge with these things.
Thanks all for your time. :pray:
If you want a cheap way to diagnose the MAF without dropping $200 (which seems a bit high), you can buy a cheapo one off Amazon like this if you 4Runner is a 99-02:
Amazon.com: SUNROAD Mass Air Flow Meter Sensor MAF Replacement for 1999-2011 Lexus & 2003-2008 Pontiac & 2004-2006 Scion & 1999-2012 Toyota Manufacturer: SUNROAD : Automotive
$20 and you'll be able to see if the codes clear. I would not trust this part to last more than a few months but it'll rule out the MAF real quick. I think it's your MAF though as I had a P0110 once and it was after I accidentally dropped the MAF on concrete and cracked the case and broke some circuit inside.
If you have the large 'turbine' style MAFs then I would recommend pulling one off a junkyard Camry, mid-90's with the V6 engine. They are identical to our 4Runners and I ran one for years.
Also, McGeorge Toyota sells the DENSO MAF for only $98: 1995-2000 Toyota Mass Air Flow Sensor 22204-75010 | Toyota Parts
Check the wiring for the maf. A short in the wiring will cause p0100, Also the ground wire. the other code might be secondary because of the short.
edit: This is the same answer as your other thread, where you posted.
Stick with your gut and try to check your fuel pressure.
I'm new to a 4runner and Toyota in general so I cant help
on how to go about it. I would agree it sounds like your fuel pump took
a crap in a short time with the baseball whack and all.
Good luck
The MAF is the primary sensor for fueling so if the MAF is out and not providing a signal, the ECU cuts fuel electronically. My money's on the MAF sensor needing to be replaced.
