3 inch lift with stock tires pics?
02_SE_Runner
As the title kindly states, do any of you have pictures of your 4runner (preferably 01 or 02) with a 3" lift with some stock tires? I am trying to see if it would look goofy if I were to do my suspension before I did tires.
Thanks in advance.
Nate..
here is a 99
2001 SR5, 3" front (Eibach & Taco Billies), ~4"rear (8 wrap LCs).
It looks fine temporarily, IMO. Heck I've had it this way for like 2 months as a DD now and its does ok on trails too. And this way you won't be limited to 265/75 or smaller tires if you want to go bigger when you upgrade. So yeah its ok to drive!
lifted.jpg~original
I don't think it looks bad but it feels skinny. Working on refinishing my tundra wheels so I can get new tires but will probably throw some 1.5" Spacers on first to see what it's like.
I've driven mine lifted with stock tires since may, and it might look a little goofy, but it's not bad. I think what was worse in my case was the sliders sticking out way farther than the tires. That's been solved with some spacers and 285's :)
Definitely worth delaying the financial blow of the lift and tires on the same credit card statement :D
This. I think with a lifted rig on the stock tires it emphasizes the narrowness of the wheels. You should also ask to see if someone has any photos with a lift and stock wheels and tires with spacers for comparison.
Tread design also plays a big role. If you have a more aggressive tread pattern and sidewall, that will offset the overall size on a visual level.
Here you go.
3" suspension lift
2" body lift
1.25" wheel spacers
255/65 16 Michelin tires
2012-01-08_16-17-55_258.jpg~original
SS 1.2 lift. 2.5" front, 3.5" rear
Tires 265x75x16 .... ~ 31.5" tire
Pics inside link below. Sorry but I'm on my phone so I can't link easily.
Little more than 3, but with 275/65/16. Tires look a little small. Going to bump up to 285s for the street, maybe 35s for the trail.
Couple flex pics....
I'd love to get to this height. I presented this idea to my local off-road guy and he said if I wanted to add a body lift to the bill stein shocks, I'd have to adjust the steering rack, bumper, and a whole host of other things in order to do a body lift right. Did you have the same experience?
Here you go.
3" suspension lift
2" body lift
1.25" wheel spacers
Here's my 4runner with a 3" lift and stock tires. In my opinion, it looks a little goofy when looked at it square on from the side. But, from most other angles the stock tires look fine. Of course though, bigger tires will transform a build. In the end I opted for 33" Toyo Open Country ATll
