3" lift question
bubbasmeat
I have a 2007 v8 4x2 sport runner. I just leveled it using the 2.5 daystar. I did not use the 1.5 in the rear. I ended up getting a full 3" lift in the front, which I needed every bit of. Now it is perfectly level. It looks really good but still has a pretty low stance in my opinion. I want it at least 2" taller, but wouldn't mind more. This is strictly for looks by the way(no off-roading). Here's where I get confused. The front is already lifted 3" just to get it level. If I were to do the Toytec Ultimate 3", or the OME, will I get an additional 3" lift. Which would mean the front has now been lifted 6" and the back 3"? Any help is appreciated. I'm wanting to purchase the lift tomorrow or the next day, but don't want to waste my money if the front isn't going to get any higher. Thanks.
you cannot stack lifts. Its a substitute for the daystar, not an add-on. Youd be 3" front and rear so you would maintain the extreme rake these have from factory, just 3" taller.
Since you are 2wd, you can get a total chaos lift spindle in the front, which will net 3.5'' of lift, which then you can keep your daystar spacer, or swap out the entire front coilover assembly for a lift kit, such as toytec ultimate.
TOTAL CHAOS FABRICATION
(Scroll down to find them)
MMJR_T4R
