Okay, well I think I finally resolved my leaking issue. After a lot of frustration I tore the front axle apart and replaced the front intermediate shaft bearing in the differential tube. This was not an easy repair. It does require removing the CV, dropping the differential (I didn't completely remove mine, just dropped it about 4 to 5 inches), removing the add shifting fork assembly, and removing the differential tube assembly. If you haven't ever taken your front diff axle assembly apart before you will need to drop the front diff completely because Toyota puts locktite on the bolts and it sometimes requires a torch to break the locktite loose. Luckily for me I had the axle totally apart before when I re-geared it.
I did have to take the differential tube to a shop to have the clips removed, the old bearing pressed off, and the new bearing pressed on. The bearing was $40 and the shop charge was $50.
This is the old bearing:
<a href="http://s124.photobucket.com/user/Robert_Harris32/media/DSC06427.jpg.html" target="_blank"><img src="http://i124.photobucket.com/albums/p31/Robert_Harris32/DSC06427.jpg" border="0" alt=" photo DSC06427.jpg"/></a>
This is the new bearing:
<a href="http://s124.photobucket.com/user/Robert_Harris32/media/DSC06436.jpg.html" target="_blank"><img src="http://i124.photobucket.com/albums/p31/Robert_Harris32/DSC06436.jpg" border="0" alt=" photo DSC06436.jpg"/></a>
This will give you an idea of how far the seal needs to go into have a good surface to bond to:
<a href="http://s124.photobucket.com/user/Robert_Harris32/media/DSC06429.jpg.html" target="_blank"><img src="http://i124.photobucket.com/albums/p31/Robert_Harris32/DSC06429.jpg" border="0" alt=" photo DSC06429.jpg"/></a>
It took me a few tries to get the seal in straight, it's very easy to put it in crooked. This is how I finally installed my seal which seemed to work. I'm posting these photos because I couldn't find any pictures online to help me out when I was doing mine. I hope this helps spare some of my fellow Toyota drivers the frustration I went through.
<a href="http://s124.photobucket.com/user/Robert_Harris32/media/DSC06438.jpg.html" target="_blank"><img src="http://i124.photobucket.com/albums/p31/Robert_Harris32/DSC06438.jpg" border="0" alt=" photo DSC06438.jpg"/></a>
<a href="http://s124.photobucket.com/user/Robert_Harris32/media/DSC06437.jpg.html" target="_blank"><img src="http://i124.photobucket.com/albums/p31/Robert_Harris32/DSC06437.jpg" border="0" alt=" photo DSC06437.jpg"/></a>
