30" LED Bar Behind Lower Grill
ARK_SWAMP_RIDER
After trying my 30" Hanma bar on the roof rack, I decided to move it to the front bumper for various reasons. I really didn't want to cut any plastic or drill holes in the bumper as others have done, so this is what I came up with.
I started out using Momo's write-up as a guide and made 4 L brackets. Getting the bolts through was a little tricky, but was eventually able to get it done. Instead of making it a 90 degree bend, I had to go a little further because the light hits the angle iron and you're limited as to how high you can aim the light. The angle of these brackets allows a greater range of motion (can angle the light down a lot, but not very high up).
IMG_0445_zps2b04985a.jpg~original
I then took a 36" piece of 2" angle iron and bolted to the L brackets.
IMG_0437_zps5df47f81.jpg~original
Then I mounted the light bar to the angle iron (only two brackets shown, there will be a 4 actually installed).
IMG_0441_zpse81354c7.jpg~original
You can't fit the assembled light bar and mount into the spot behind the grill. I had to take the light bar attached to the angle iron and put it in place. Then I was able to bolt in the 4 L brackets. It's a tight fit but there's enough room to get the job done.
IMG_0449_zps2ee34092.jpg~original
View from the top:
IMG_0448_zps5597e5e6.jpg~original
All bolted up:
IMG_0446_zpsa673a0c3.jpg~original
IMG_0455_zps73cd2ce1.jpg~original
IMG_0460_zpsf07a5f16.jpg~original
IMG_0463_zpsad861e8d.jpg~original
I'll try to get some output shots soon. It doesn't seem that much light is blocked by the lower grill, which was a concern I had going into this project. I tried getting the LED's aligned in the openings as much as possible, this helped I'm sure. The mount is very solid, I don't expect it to shake at all. I'll have to report back on this. A lot of this was trial and error, so I don't have any detailed measurements or anything. I just went one piece at a time and had an idea of what I wanted. It's a pretty simple design, just takes some time to get everything lined up.
that turned out really nice. Can't wait to get one and do the same. Thanks for the write up.
Looks great Ark!
How is the aim? High/low? The lights seem to throw so much light downward immediately in front that I was afraid to put mine so low.
Glad to see it works now what's going on with non-functional one? If you're not dissecting it I'm going to need it back for the "warranty return" :hungry:
edit- did you get the floods put on for backups or are those still the spots?
Thanks everyone!
Looks great Ark!
It's aimed a little high right now. You're right though, a lot of light right in front so "ideally" it would be mounted higher, but I'm pretty happy with how it turned out. I'll know more once I have time to get out in the open and get it aimed properly.
I haven't done anything with the old bar just yet. I used it for all my test fitting so I wasn't beating around on the good bar, wanted it still together for that. I'll get back to you on this...may let you dig into it.
Yea, I swapped out the spots for the two floods. Much better coverage overall. I also moved them a little further towards the front of the 4runner and put the rear tow hook back on, so it provides a little more protection.
IMG_0465_zps4cc6656e.jpg~original
IMG_0458_zpseeaef78c.jpg~original
Sweet
Hilarious! I was just looking at my runner not 3 hours ago scheming about how to do the same thing; although was going to do two separate 4" or 6" bars to go either side of the winch via a CBI front receiver I am planning to order.
Great to see how you got it done! Looks great!
Love rear floods as well, do you have the front and back wired together or separate switch
That looks awesome Ark! I've wanted to do this for a longtime but just never took the initiative to do it...or buy the LED bar Ha. I love the location (very stealth), especially for us without a front bumper to mount it on. This may be enough to push me over the edge.
You didn't have to cut that bottom lower grill out? I am about to get the 30" Hanma and do this, I thought for sure the plastic bar would effect the output.
Thanks for the compliments guys! I'll try to answer all questions....
I have two switches mounted in the ash tray in the center console, one for each. The front one (closest to the cup holders) is a little difficult to turn off, but I rarely use that one (it's for the backup lights, I have these wired so they come on automatically when in reverse or with the switch). These are just cheap toggle switches from RadioShack. I was going to use the OEM FJ switch, but my dog rides on the center console and has a tendency to hit the buttons there, didn't want to blind someone with the LED bar if he stepped on the switch. 4runner is a little dirty, needs an interior detail pretty bad so excuse the dirt.
IMG_0456_zpscbd36d0b.jpg~original
IMG_0457_zps12309798.jpg~original
I've been wanting some aux lights for a long time, at the price of this I couldn't pass it up! Excellent value and incredible output.
No....this is a 100% bolt on solution. It sits behind the grill and absolutely no trimming was required. I'm sure the plastic does block some output, but this thing also emits a ton of light. The little bit that is blocked seems to be negligible.
Also, thought I'd show this as I really haven't seen it done here, got the idea from Tacoma World. I have a inline fuse and relay for both the front and rear lights. I wanted a way to keep things hidden, so I went to RadioShack and purchased a project box. Drilled holes in one end and bolted it to some existing/unused holes in the engine bay. Both relays/fuse holders are in here and all my wiring comes in a hole through the bottom.
IMG_0452_zps0f3621d7.jpg~original
Nice work ARK,
I was just at Home Depot this afternoon looking at the same piece of angle iron to do the exact same thing. Hopefully I can find some time to complete mine this month. I'm still trying to figure out which switch I want to use, and where I want to put it though.
Thanks for the write up!
I like the set-up ideal, but here in MD, I'd look 1/3 of that light bar because of the front tags.
Is there enough room behind the top grill to do this?
Nice work ARK,
With the help of ASR, I have started this exact project. Here are the switches I chose (Ottrattw) - since that picture was taken, switches have been wired and dremeled to fit. Sorry for the large photo. Overall it Looks great!
Wow, great project ARK, love this look. I had been toying with something like this since I'm trying to keep a stock stealth look. Definitely have the wheels turning now.
Rig, can't wait to see how yours turns out
johnnya
