300k daily driver
Been reparing my 2002 4Runner and nursing it along since new. Got 307,456 MI to date.
Since the life of the vehicle:
1) 3 timing belt/water pump changes
2) 5 sets of tires
3) fwd catalytic converter replacement
4) upper and lower front end ball joint replacement
5) full set of struts replaced
6) 2 sets of drive shaft bearing replacements
7) 2 sets of spark plugs and wires replacements
8) three sets of front and rear brake pads and rotors replacements
9) 2 O2 sensor replacements
10) emmision system EVAP cannister and check valve replacement
11) Fuel pump replacement
13) 2 fuel tank cap replacements
14) Numerous exterior/interior lights & lamps replacements
15) Electric stowable radio antenna replacement
16) 3 windshield replacements
17) Numerous engine oil, air intake, transmission fluid, differential hypoid fluid and filters replacements
Bought my 98 recently right as the clock rolled over to 271. Pretty good maintenance on it and it runs great right now, engine purrs. Definitely hoping for 300, 400 and God willing 500k on this. I wanted a vehicle I could turn a wrench on again and I'm sure I will get plenty of opportunities. Last vehicle was a 2017 Rogue, too much electronics and never even did my own oil changes, only changed the pads and rotors on the rear. So far after two weeks I've done some flushing of the clutch MC fluid, still need a few more cycles to get it clean and might have to do a bleed, and an oil change. Pretty cool being able to change the oil without stands or ramps with the 2" lift and 265/70r17s it came with. Nice and comfy under there on the creeper I haven't used in years that finally gets some love. Also nice with how much the lube techs are charging for labor these days (I hope that means they are getting paid well, I know I wasn't back 12 years ago when I did it lol).
