36000k
darktiger
Okay I have 35700k miles on my 04 SE 4runner. Do I need to bring this into the dealer to take a look at anything before my warranty wears out?
NO. If nothing broken, then there is no need to stir things up. Steeler will try to sell you some crap that you wont need, such as exteded warranty or some $200 worth of oil change and "20 point inspection" (read: $19 oil change and mechanic Earl actualy looked under the hood).
I'd check for any outstanding TSB's that still need complied with and get them done. For example the sulphur smell/bad cats one, the drivers seat rattle/looseness one and so forth. Won't hurt to look into those.
If you are at all interested in getting an extended warranty, the 100k top of the line ones can be had for ~$900.00. But that is up to you. If everything is in good working order, don't worry about it.
I say take it in. It can't hurt for them to give it a once over and let you know of anything that will need to get worked on (can't imagine much as you probably had service done at 35K) but who knows. Most TSBs have a month/mileage expiration date and some are over the standard 3yr/36k warranty (for example the Sulfur TSB on 2004 V6 is I believe 96K miles)
If you want to get an extended warranty it is up to you. Check on the forum because there is a Toyota contact that can get it cheaper than most dealerships.
Even if there is something wrong with the car when, "Earl," looks at your beast, who is to say that they will change out the problem prior to your car showing symptoms.
CV
you know that.. "k" means thousands... so ...
36000k means 36,000,000. so what you mean is.. 36k miles. :D
try to get the little stuff replaced if possible. like bulbs and wipers... they add up.
