Moroney167
Selling my end caps I had purchased new from a member here. These are 3D printed end caps. I had paid extra to have them smoothed out. I did sand them down and maybe went a little to much because the plasti dip I used to paint them did not fill anything in to well. However, a few more coats could do it otherwise just need to resand finer and paint again. I filed down any mounting area of bulges so they should mount easier. I have not installed them and its been over a few months. Hopefully someone here will enjoy them more and at a cheaper cost. I have mud flaps installed and don't feel like trying to make it all fit. Pictures show a sort of white color change, that is a spot you will not see I cleaned them with a brake cleaner and it did that. I just didn't paint over it. Plasti dip also started to puddle up a bit again in a spot you won't see. I put heavy coats on because I found it came off easier and would help fill the sanding marks.
Asking $80 and that is SHIPPED to lower 48 states
Located in NY
Jim
Located in NY
Jim
