3rd Gen 4Runner horn upgrade
4wd4runner
We all know how embarrassing the horns sound on the 4Runners, so I wanted to know if the horn on a 1999 Tacoma will be a direct plug in since I think it sounds a lot better
just go down to the auto parts store and buy a set of f350 horns for a full size ford truck. problem solved and it will have more ummmph than the taco horn
I can confirm that newer Toyota horns fit, I checked the connectors on my dad's 04 Tundra a while back and they are identical. If I'm ever at a junkyard I'll scrounge around for some. They are on many models.
I've got air horns. Wakes up pesky distracted drivers
My comment is totally off topic per say, but as a former truck driver, I have to say that I've had many a good laugh at my fellow truckers expense when they would make the mistake of driving over a set of train tracks while I was nearby.
I would wait untill they were committed to crossing and then I would lay on my air horn...instant pucker-factor of about 7 or 8!
It's in that split second after hearing a loud horn—that the brain doesn't distinguish the difference between a truck horn and a train horn. Hahaha...
This was usually followed seconds later by either anger for being tricked, or giddiness for not getting squashed by a train.
Maybe I should get an air horn for my runner too. :horn:
I grabbed the horn from a 70's f250 at a junkyard for $2. The connector fit but the bracket needed to be bent slightly. Easy enough.
This was my route as well, It was a pretty simple job all in all cheep too and the truck sounds like, well, a truck now not a vespa. I believe the horns are Fiamm or something Italian like that.
So you're just an *******? Got it.
My 98 taco had a weenie horn. I can confirm that the 2001 4runner stock horn is pretty ballsy, though.
I used to have Hella Supertones and I loved them at first but after awhile I thought they sounded out of place so I sold those to a friend with an accord and picked up a set of FIAMM El Grande horns. They are great sounding horns IMO. They are loud, sound truck like and sound OEM'ish as well.
Toyota's been using the same horn connectors since...forever LOL. My '00 Tundra had weak horns,used ones off an LX470/Landcruiser,direct plug n play. Did the same with a 94 Supra.
Another option are cheap (usually on sale for $9.99) chrome harbor freight horns. They sound like domestic vehicle horns but aren't a direct fit. Don't like the blingy chrome? HF also has cheap spray paint to fix that. I installed them on my dad's CRV,powered by a relay triggered by the factory wiring. It's been close to 4 years since I installed them and no issues.
I picked up a couple '90 F150 horns from my local junkyard, but only one ended up working so kept the original. The combination sounds pretty funky and unique but I kind of like it!
My F150 horns point straight up, so I removed the cover from the stock horn, bent it a little in a vice, and attached it to the nearest bolt so the horn doesn't fill with water next time it rains.
