3rd Gen 4Runner Lift Information and FAQ's
They do not work.
What is it about the coilovers that doesnt work, is it the mounting plate on top? Or the coil springs themselves. Too big or too tall?? I found a set at a junkyard, but dont want to go to the trouble of removing them off the truck just yet.
I ask because if I cant bolt up the whole thing, then I wonder if I could use just the coil spring and my top plate and shock.
I believe the coils are the wrong diameter and the bolts don't line up. I'm not 100% sure on that, but I don't know of anyone who has sucessfully made it work so there is definitely a big issue to overcome. The FJC and 4th gen 4runners I believe are compatible.
Ok good to know, my only reason for thinking they might work was that I just looked on Toyteclifts.com, and they list OME 883's as an option for 05-10 Tacomas, which are also an option for 3rd Gens as well. I think I will go ahead and risk the money on this set I found and see how it works. Thanks for the insight though.
i think the coils themselves would probably fit and you would probably get some lift from them too. but i am pretty sure that the shocks would be way to long.
Listen to Steeze, he deals with lifts for all years and has far more knowledge about that than I do. You're right, I didn't think about that 883s are taco coils 1st and formost.
so does it matter if i use front or rear LC coils? for the rear of my runner? i am looking into doing the lift, thinking that i will go with toytec front coil overs and then the fj80 LC 8wrap coils and a 1 or 1.5 bl. ill prolly also just end up using the Bilstein unless i can find a tundra trd front setup
read below. The front coils go in the rear of the 3rd gen. the rear coils go in the rear of the 2nd gen
The FJ80 Landcruiser Spring
a cheap effective way to achieve a good amount of lift and flex is to install FRONT springs from a FJ80 (1991-1997) Landcruiser in the REAR of the 3rd gen.
It's surprising how much you'll learn about your suspension when you install the lift yourself. I know not everyone has the means to do it, but if you can I recommend it. Then when/if something breaks on the trail you'll know what it is, why it broke, and what you can do to prevent it from happening again.
I ordered a 3 inch spacer for the front of my 1997 t4r and 2 inch spacer for the back. when I got it they sent me a '06 to '10 fj rear spacer. I have read that they will fit the 4th gen t4rs but what about the 3rd gens?
what company did you buy it from
DJNutshell
