3RD Gen 4Runner moonroof drain tube location?
hawkcharmer
Member
Although I have an aftermarket moonroof, It was installed by Toyota the day it was purchased new and looks very much stock. I'm trying to locate where the front and rear drain tubes exit the bottom of vehicle. Are the tubes supposed to be visible from the bottom? I'm getting a wet carpeting and their are no leaves blocking up top.
I have been pouring water into the top drain tubes and it seems to be escaping through a seam on the body by front doors. Not sure this should be leaking through a body seam?
In the rear it escapes by end cap but I cant locate the tubes.
Does anyone have any photos or know where these locations are exactly?
Any feedback is greatly appreciated. Thank you
Where is your carpet wet? Passenger side? Driver side?
It's normal for the front drains to drain out under the front fenders by the door. You can't see where they end (I don't think).
Hmm...
Would any of this have any connection to my left foot getting wet when I run it through an automatic car wash?
Drains empty in bottom of fender between front of door and back of tire. If your feet are getting wet id same you might have some rust or a plug/rubber grommet in the fire wall missing or leaking.
tobasko556
