3rd Gen Camburg Coilovers - Santa Cruz, CA - $600
SCRunner12
I have a set of Camburg coilovers I bought for my 06 Tundra but now could really use the money instead. They have minimal miles (according to the PO) and based on the condition to be true. No leaks and shafts are perfect. Come with a spanner wrench as well. These will fit 2000-2006 Tundra and 2000-2007 Sequoia applications and can be used on 96-04 Tacomas and 96-02 4runners. They came off a Tundra, but the top plate has mounting holes for both Tacoma/4runner and Tundra/Sequoia.
Located in Santa Cruz, CA and $600 obo plus shipping.
SOLD
I'm interested, let me do a little research because I am not familiar with cam burg. They would be going on a 96 4Runner.
Edit: Are these the same as kings just with different branding? I am worried about the valving will be off since they are not meant for 3nd gen 4Runner. Don't want to end up with a really stiff front end. I have read the Kings ride nice though...
Sounds good, camburg coilovers are essentially the same as Sway a way coilovers. They are identical and I believe the same manufacturer just rebranded for the Camburg name. Would be putting them on this weekend but just got a $500 pg&e bill at my new place...so these need to go haha.
I'm interested in these too. Are the springs progressive, do they lift? Thanks.
Pretty sure all Coilover springs are linear but I could be wrong. The valving is progressive which will be softer at low speed so better for city driving. They can be adjusted between 0-3" of lift. Just crank them up or down depending on what height you want.
Forgot to mention, I can swap the springs out for a set of 13x600lb from my old fox. Only 8k on the 600's and are silver.
Just doing a little more research. Just wondering whether I'll like the Bilstein and tundra spring setup better. Might be splitting hairs. I'll try to let you know as soon as possible.
