3rd Gen Component Crossovers
inside the door cavity, with double sided wether stripping tape. I'm probably going to move them when I put my new speakers in though...
So not in between the door and the door molding but inside where the glass is?
I tried in between the door and the door molding but I think the x-over is too thick with the cover on. It "works" but the molding doesn't snap back into the door like it should and juts out towards the hinge. On the passenger side I decided to run the wires into the cabin and put the x-over into the holder next to the speaker until I find a better space. Only reason I had to do this was I already had cut out the tweeter hole in the stock locations before I knew the fitment of the x-over would be an issue.
This is true..... I just wasnt sure if there would be clearance issues with the window. I know I could some test fitting, but it is too damn cold to be outside for the time being.........
my brother's truck had his crossovers installed inside each of the four doors, sitting just below the speakers..they're not getting in the way of the window mechanism.
I agonized about this very thing when I decided to install my current system. 4 crossovers, 2 on each side of the rear passenger seats under the carpet. Affixed with velcro. It's otherwise unuseable space. In my 3rd Gen, the carpet just bulges out a bit but still tucks under the door sill. You'd never know they were there. Also, I'm not using any of the factory wiring.
