3rd gen eLocker axle 410 gears w inchworm gear wiring
TruckTreeHouse
So up for sale I have a complete elocker axle with actuator set up for abs, rear drums, and axle shafts. The third member currently has a trashed 4.88 gear set but included is a second 3rd member with 4.10 ring and pinion. The wiring coming out of the actuator will need a little TLC as one of the wires is broken close to the housing, and another one is broken at the connector plug. This is an easy fix by disassembling the actuator and re-soldering the wire.
I also have a basic set of inchworm gear wiring and switch to work the elocker.
The elocker is in good working order, and worked completely until it was removed from my truck. Buyer can connect to 12v to verify that it operates.
I also will throw in upper control arms and a stock sway bar if the buyer is interested.
$550or best offer located in southern
MD.
Pm, text, or call 240-298-8674.
I bought this truck with the axle gears an locker already installed. I removed this when the 4.88s gave up. I already have and arb air locker in the front and decided to go with the same in the rear for simplicity.
I have had issues in the past with the inchworm gear switch as I didn't have any pre wiring for the locker, and would suggest to any buyer that isn't pre wired, to go for the 12v guy 1 piece wiring switch as its very clean and much more thought out that the inchworm gear switch.
