3rd Gen: turn signal causing downshift
diponyou
Hey guys, so I just picked this 1999 4runner up and it runs amazingly.
The only issue I have come across is that when I am traveling over 50mph and I use the blinkers the truck will downshift out of overdrive.
It is really peculiar
Also something to note is that when you use one of the blinkers you can hear the solenoid in the center console by the shifter(I am assuming overdrive solenoid?) activating as the lights flash.
I know these have minor electrical grimlims but I can't seem to find any threads with a similar issue.
You are the man!
I honestly did a lot of searching and could not find a thing.
Thanks again I am going to go check it out in a little bit.
Ok guys got it figured out.
It ended up being both brake lights were out :faint2:
Luckily I found out right after I got the truck.
All is good now.
Something else to note. I was having issues with the fuel gauge not working as well. After fixing the lights it has been working. Not sure if it's just a coincidence or what.
tuṣṭāva
