Alright guys, it's been a while since I posted anything.
The 4Runner (99' base 3rz 4wd) has been a little sluggish for a while now. I would say nearly a year but I don't use it as a daily driver anymore.
Got under the hood today and pulled the valve cover to check the clearances, inspect timing chain and guides, etc.. While intake valves are all within spec but 2.5 of the exhaust valves are too tight to fit my .005" feeler gauge under, and the other 1.5 are in the .008-.009 reading. Before I go any further with adjusting I'm hoping someone can chime in and let me know if I'm in more trouble than I think, or if I should just go ahead with the adjustment. Are those valves burnt and am I looking at a head replacement? Has anyone come across this before?
When this all started happening I had found a burnt catalytic converter and suspected it was because of my slightly dirty Egr valve, which I cleaned and replaced the cat. I haven't checked the new cat yet, but I suspect this may have been the underlying issue that I missed from the get go.
Any help would be much appreciated. I'm very capable to do the adjustment, but would like to know if this is indication that the head needs replacing.
