4.7 sounds like supercharger on cold start. Not the air pump
bubbazr2
When I start the engine from cold, the engine sounds a lot like its supercharged. A belt type "wwwrrrrr" sound. I'v already done the air pump bypass, so I'm not entirely sure what it could be. It goes away when the engine warms up. Any ideas? Its an 07 4.7 4x4. Thanks for the help! :frusty:
Get yourself a mechanic's stethoscope and pinpoint where the sound is coming from, just be very careful not to stick it into any moving parts, you can get them at any auto parts store for around $7 to $20 and very good ones can go upwards to more then $100, but the basic less expensive ones work well enough and you'll be amazed at how it sounds up close and personal when you actually pinpoint where the sound is coming from, and if it is your alternator you'll know once you stick the probe on it.
Just don't confuse normal engine and components sounds from abnormal ones, you will be amazed at all the different sounds that make up the normal sound of your engine running when you isolate each of the sounds with the stethoscope.
Fan clutch? It can make quite a bit of noise on a cold start while the engine is over-revving until the clutch fluid has a chance to move outward and allows the fan to slow down.
