For me, this is how i would use the system. TRAC is for on-road all-weather use. I would not rely on it off-road. Off-road, you use A-TRAC and/or rear locker. Terrain Response or Crawl Control is good when you're in 4-HI. When you need 4-LO (aka severe terrain), i would just rely on A-TRAC and rear locker and shut everything else off. If you're not sure of yourself in terms of speed, then use CC in addition to A-TRAC and locker.
Can someone put this up on Google Docs so that we can save and print this?
Thanks for taking the time to do all the work!
I do not think Crawl Control can be engaged in 4H. And only one of the Multi Terrain modes is available in 4H, the other 3 can only be used in 4L. Perhaps someone else can confirm; I don't have my Trail today.
Well, then (for me) that makes CC and TR useless. I will stick with the "old-tech" A-TRAC and rear locker.![]()
What's TR?
What's TR?
CC is great for the trails that require you to hang out the window so far you can't reach the pedals.:jump:
I confirmed you can turn off VSC and TRAC if you hold down the VSC button for 3 seconds but you have to be stationary to turn of the VSC and slow to turn off TRAC. Also tested that it doesn't turn off by itself at speeds over 30mph (tested to 70). Tested in 2Hi and 4HI.
That makes sense: VSC & TRAC are for normal driving and should not turn OFF by themselves. It an option for the driver to disable them if stuck in mud or fresh snow by pressing the button. It will turn back ON via the button or by turning engine off, then on.
