4Runner 3rd member Rear Diff Turbo/V6
ChildrenOfBodom
Moderator
For sale is my 3rd member differential from my 1999 4Runner. It's the newer designed housing (stronger). No damage, Works great, has 3.91 gear ratio. I regeared to a 4.56 diff. Even if not interested in gear ratio, carrier is excellent
Known as the Turbo V6 8" diff. Should fit the following. Please be sure it will fit your truck:
Toyota Pickup Turbo or V6 (86-95)
Toyota 4Runner Turbo or V6 (86-95)
4Runner 1996-2002 (4 cylinder and 6 cylinder)
Not 100% but I think it may fit 4th gens too
It does not fit 4 cylinder N/A 4Runner or Pickup models pre-96
$100, Trades will be considered, I am interested in hubcentric spacers, front suspension parts, and other stuff. surprise me.
Some Info on this diff:
'86-95 4cyl Turbo and V6* trucks and 4runners, and ALL '96+ 4Runners use the Toyota 8" 4-pinion differential in the rear. This diff is known as the "V6/Turbo diff."
- Stronger housing than the 4cyl NA diff
- Larger carrier bearings than the 4cyl NA diff
- 30 spline axles
- 27 spline pinion (pre-'96)
- Ten 10mm ring gear bolts
- 8mm axle housing studs with 12mm nuts
- 4-pinion carrier (case)
- A few pre-'96 V6 trucks and 4runners have been found to have come with the 4cyl style diff from the factory. Nobody knows why.
'96-up 4runner V6 diffs:
- new improved housing that looks the same as the T100/Tundra/Tacoma diff on the outside, internals are all the same as the regular V6 diff
- 30 spline pinion on OEM gears, swap pinion flange to 27 spline to use aftermarket gears
VERY interested in purchasing.
I have a 94 v6 5spd 4x4. 4runner.
will it fit for me? should I take a picture of my rear and u tell me if it will fit or what should i measure?
currently theres 4.56 in there
Fits all '86-95 4cyl Turbo and V6 trucks/4runners, although, A few pre-'96 V6 trucks and 4runners have been found to have come with the 4cyl style diff from the factory. Nobody knows why.
patnewton
