4runner clock continuosly resetting/fast forwarding???
speedgoat
I have a 2000 limited. The minutes on the clock are perpetually in fast forward, as if I were holding down the min button to change the time. Is the clock about to bite the dust or is there something I can do?
Thanks!
Is it as simple as something has stuck in between the button and trim causing it to be held down?
Not trying to be a smart*ss but I've had a clock do that and found a little piece of something that settled in the crack when the button was pushed.
Thanks!
I would stay out of that thing if I were you. Your probably aging at a much higher rate!
