coolant
x2
Year, engine, mileage etc would be good......
If the exhaust smells sweet though, that is a sure sign of burning coolant (head gasket)
I will check for bubbles from radiator
But I do not get the following
Milky Radiator Fluid
Water In Oil
Over Heating Problems
No coolant or oil running from head but the engine its self looks really greasy.
Never loose oil
No White Smoke
Engine May sound a little Airy, Thought Exaust pipe is totally red and looks like its about to rot out. I know the muffler was replaced and I was planning on replacing the whole exaust. But can a cat cause this?
that seriously sounds like the headgasket went.
Water In Oil
Never loose oil
No White Smoke
Clean up the engine, check the fluids...........
Water is a byproduct of complete combustion so, yes eventually any mild steel exhaust will rust out.
if coolant was burning would that cause it to rust faster?
I just checked my radiator no bubbles
Fluid is same as I left it about 2 months ago.
No white or mily ring around oil cap.
It seems impossible to clean this engine how do I go about that? I really want to but pressurewasher could damage electrical and plus it doesn't do a good job anyways..
Oh and Im glad I went check under my vehicle I found that my tranny was leaking, I forgot to tighten the drain plug all the way thankfully.. But Im glad I caught it early, levels are fine and Ill fix it and add a little tomorrow..
Water In Oil
Never loose oil
No White Smoke
Maybe Mr.B missed the following, reading your post too quickly?
Yea prolly so,
I was planning on doing simple green and a few brushes this weekend, but it just seems like its gonna be a pita..
It will, :bigok:
If you get her clean though, you should be able to find what's making her greasy/oily a hell of a lot easier.
I thougt it was just from being 12 years old with almost 200k and not much loving. But I have the day off and need to not spend money so this sounds very good. Thought Ill prolly go out and buy a bunch of brushes..
Thanks for the replies. Ill figure it out eventually for now she runs fine and all.. Now one to make another thread..
Actually one more question lets just pretend it was running rich, then what?
