4runner sleep Platform: Keep It Stupid, Simple!
Martinjmpr
Just finished a simple sleeping platform/extender for the 4runner, figured I'd share it with the group. I was able to make mine from stuff I had at the house (actually, parts from the last sleeping platform I made for my Taco last year.)
For people under about 5' 5", no modification is neccessary to sleep in a 4runner. Just flip the seat bottom cushions forward, then drop the seat back, and go to sleep. However, for those of us who are taller (I'm 6' 1") that doesn't work.
First thing to do is remove the seat bottom cushions. The good news is that it's quite simple: A socket wrench (12mm socket) removes the 4 bolts (2 on each seat cushion) and they just lift out. Sometimes the seat brackets still have the little plastic covers on them, but they can just pop off by hand.
2010_0822_155803AA.jpg~original
What you're left with is this, which is actually a pretty decent amount of room:
2010_0822_160444AA.jpg~original
The problem is this, the gap where the seat cushions used to fold up:
2010_0822_160427AA.jpg~original
The other issue is that the seat back cushions, when laid down, still slope slightly, which means that sleeping with your head by the tailgate and just letting your feet hang down isn't really an option (because you always want your head higher than your feet.) So, it was neccessary to fabricate something to cover that gap, which is approximately 8" wide.
I started with an old piece of 1/2" plywood I had from a previous project, and cut it down to 44" wide and 12" long.
2010_0822_163026AA.jpg~original
Originally I was going to have two "legs" but after I looked at it I thought I could get away with a "monopod" since it wouldn't be bearing a lot of weight anyway. Going with a single support leg also kept me from having to make sure both legs were exactly the same height. Leg is a 7 1/2" long piece of 1 x 2" furring strip. I drilled two holes in the wood platform and then put in 2 1 1/2" countersunk wood screws:
2010_0822_173317AA.jpg~original
Finished product, pre-carpet, is pretty small:
2010_0822_183922AA.jpg~original
I had some indoor/outdoor carpet from my previous project and that was cut and stapled on:
2010_0822_185535AA.jpg~original
Put in place, it sits like this:
2010_0822_185625AA.jpg~original
As you can see, the leg is resting on the driveshaft hump:
2010_0822_190714AA.jpg~original
Notice how I can still use the rear seat cup holders, which is nice so I can keep a bottle of water there by my head while I sleep.
Here's the entire cargo compartment:
2010_0822_190455AA.jpg~original
Simple, but it should work. I'm a little concerned about the "drop off" of the edge of the platform, but considering that's where my head/pillow will be I don't think I'll notice it much. May or may not use a sleeping mat or air mattress. Total sleeping length is now about 74" with the tailgate closed, and I can actually increase that a bit if I push the seats forward.
Not sure when I'll get a chance to try it out but I'll see how the one-leg design works then.
Total cost was $0 to me because all the materials were stuff I had, but anyone wanting to make one should be able to get everything they need for less than $20. Time was about an hour, give or take.
Best of all, it's completely "convertible." I reinstalled the seats after finishing this.
Just got back from camping and I removed the lower seat part which definetly made things flatter but for sleeping we just parked on a slight incline front down and used these large camping pads that covered the floor from the front seats to the back and we slept with our heads at the rear so no issues with the gap.
where did you get those seat covers
They're wal-mart cheapies. Starting to wear out already after just a year. I think I paid around $15 each for them.
To me seat covers are more or less disposable. Like a tablecloth, their purpose is to protect the seat.
I did like Army digital camo pattern (I'm retired Army) and I use the stretchy pockets on the back. I don't use all the other pockets, though, as they're hard to get to and seem to serve no purpose.
