4runners aren't for 4wheeling!!!
jayp1981 said:
I'm not a big fan of "luxury" items so I spent the difference between a SR5 and Limited on getting the V8 and 4 wheel drive.
Hoping to hit Hatteras Monday. We'll see how this rig handles some sand ...
... Whats better in the sand: VSC on or off?
- JP
make sure you lock the center diff (vsc off) otherwise there is a good chance you could get stuck (especially if you are at oregon inlet in the soft stuff). i had a '94 toy pickup and a '93 4runner that both did much much better in the sand than my '04. as much as it sucks, i would recommend airing down to 20 psi or less (something that i never had to do in the other trucks). this will make it much easier on your truck and save you from the potential headache of getting stuck. most gas stations down there will have free places to get air, as does the marina across from oregon inlet. have fun!
Thanks gonzo!
I emailed michelin to see what the lowest recommended pressure is for the Cross Terrains SUV tires that come with the 07 4Runners.
They say anything below 20 PSI will be at risk for popping off the bead.
Cheers,
- JP
Falls said:
My 06 was off road on some light trails with 85 miles on it.
Being in sand and salt is a completely different scenario than being on some trails.
fourwd1, I'm sure, doesn't have anything negative to say about people taking their 4th gens on trails. But salt and sand build up over time as it is near impossible to get all of the sand off. My 4Runner is a 1998 and I have no plans of it seeing sand as long as its my daily driver and actually worth something.
If I had a 1st gen I'd be the first guy on the beach!
Maybe they don't get wheeled out in Virgina...but here in Arizona they get USED!!!
They can handle it...and paint is only a spray booth away.
I live on the beach! I was a touch hesitant at first to go on the beach much, and I DO limit myself.....
Rust being the issue, i can tell you that my skid plate will probably fall off in a couple of years at the rate its oxidizing.
And as far as the 4th gen runner in sand, I personally think it is VERY IMPRESSIVE. even with the stock dunflops.
Id say that 90% of the offroading I do is in sand, all depths and grain sizes and I have never once gotten stuck or close.
even stock they are great
I would have to argue that alot of the pictures on this thread are of jackep up 4rs on bigger wheels and nice AT tires... mine does great stock, and i mean stock, still the original tires with 63,000 miles on them (need to be replaced). The only things I have done are interior and a K&N. It out perofrms the 98 pathfinder I had by leaps and bounds and except for ground clearance issues, I have been able to go anywhere my buddy can in his lifted CJ5.
look here to see
http://www.toyota-4runner.org/photo...=967&password=&sort=1&size=big&cat=3126&page=
I disagree that T4R is not only for street use.
Look at mine, have a 2wd and I take it off roading up to it's limits.
115a.jpg~original
Going up a (blue) moderate rated trail.
IMGP0683a.jpg~original
Photo op for my wife decending the Tejon Trail.
IMGP0633a.jpg~original
Climbing up, dirt flying.
089a.jpg~original
Reached top of another moderate rated trail hill.
078a.jpg~original
Front drops while blazing down trail after hitting a big dip.
IMGP0652a.jpg~original
My passengers fly up coming out of dip.
IMGP0685a.jpg~original
Deep in view of a moderate trail.
hvmap.jpg~original
Map of area, highlighted are the trails we went to explore.
mysticz,
Where are those trails located at? Is that around NorCal?
Thanks.
115a.jpg~original
089a.jpg~original
078a.jpg~original
Wow thanks! You have brought me some hope in my 2WD :) Im going to have to get me a lift kit though and some decent Nitto Terra grapplers..
Uneek said:
mysticz,
Thanks.
Those were taken up in SCal's Hungry Valley SVRA.
But Holister Hills SVRA near San Jose has similar trails. :cool:
jayp1981 said:
T?@\7 - How many miles do you have on your 4Runner?
Have you had any problems because of the sand yet?
- JP
NONE AT ALL.
I do try to be as diligent with rinses (both body & undercarriage) as possible.
I really dont have to drive on the beach much, I live 2 blocks away so i usually just ride my skateboard or bike. :-) but nearly ALL of my offroading is in sand...
Florida.... North Americas sand dune.
Ray
Hollister was pretty cool, went with my gf and one of our friends this past Sunday..got lost on the damm trail and ended up going down part of a black diamond...that was fun and no body damage...can't wait till i install my locker!
Yeah Hollister is a blast, especially getting thru some of the trails.
Is anyone going to the Oct 12-14 Pismo 4RJ event?
Here is the info link for it: Pismo 4RJ
